R34skylne said:when everybody is talkin about ome lifts are they talkin about old man emu
lee said:
lee said:4) a spacer lift is not a body lift (i know you know this, just saying), but a suspension lift
broncosi said:nope didnt know that, i had a 85 bronco previously and had a 4 inch susp lift and a 3 in body lift and the body lift was made out of 6 spacers that we put in between the body and frame. So when i head spacer i just see a solid block seperating the body from the frame.
so how do the spacers work?
lee said:a body lift does consist of putting a solid block to raise the body from the frame as you said, but what is referred to as a "spacer lift" puts a spacer at the coil, raising the truck up from the suspension up... nothing to do with raising the body off the frame.
