OMG!!! break master help!
Iroke17
Ok so i changed my break master like a year ago and it has been slowly leaking from right where the resevuar bowl mounts to it i just fill it from time to time it was poping on low fluid light every other month or so.
I changed my rear breaks and i need to bleed the breaks.
I have a motive power bleeder it mounts to top of bowl and uses pressure so you only need you to bleed and i cant get this dam bowl to stop leaking!!!
things ive done
the original one didnt have a gasket or anything.
I had to reuse the bowl from the original to the new master. Leaked
Used a hard o ring inside bowl tephlon tap on threads and rtv where the bowl and the master meet Leaked
Soft o ring inside and out side bowl and rtv around seal and tephlon tape on threads STILL LEAKING HELPPPP im going nuts
Anyone recommend anything i have literaly no breaks.
goddesszilla
