on board air
I have a small tire air compressor with me all the time. It came with my road hazard kit that i bought a long time ago. It works great. I don't leave home without it. :thumb:
Wow, that's a lot of money!!:eek2:
My air compressor is tiny compare to that monstrous thing! I am sure my air compressor is on the cheap side. It is about 1/2 a foot long. It is not particularly powerful, but it does it's job well (if you have enough patience).
I will get the brand name later...i am away from my 4runner at this time.
For me, small size is more important than how fast you can inflate your tires. My thing fits nicely within the rear cargo cubby hole. I think that you don't need to get as big as the one above...that's too big and too much $$$$.
But, if you're big into off-roading and you need to air down constantly, then that air compressor is pretty nice to have.:gaptooth:
re
i agree, its alot of cash, but i also beleive "you get what you pay for" ive seen how fast this is, i have one of them cheap wal-mart ones that plug into the cig. lighter, tried it "once" just took wayyy to long, so i just go to the closest filling station.
ricnkc,
Patience is a virtue.:D And while you wait, you can always look at the scenery or take a dump at a nearby bush!:happens: :biggrin2:
I have a thomas 12v mounted under the hood of my truck. It fills a small tank for airing up after a trip. It works fairly well. I will take a photo of it and post it. It was around $125.
I bought it off ebay. It is just like this one. .Ebay link I will post a photo of mine tomorrow.
I think it works best off a tank. It takes about 15 min to fill a 10 lb tank to 90 psi. Not strong enough to run air tools, but works ok
Re: Re: Thai
Good Times said:
I have one of those in the non portable version :) Works wonder man w/ the 100% duty cycle!!!
Lance - did you ever do a write-up and photos?
I like the idea of the bigger compressor and heavier duty cycle being on board, even if you don't go offroad. But I don't see how you fit it in the engine compartment, especially if you have an air tank, too, so you can run some tools.
Now, getting the Finance Minister to agree to $400 for a compressor (more expensive than the one in the garage) is another thing..... :blulaugh:
Yes, there is plenty of room right behind the bumper. It looks like you could simply strap the tank to the bumper and have the air hose hookup coming out the front of the stock bumper so it is very convenient.
Wiring looks pretty simple, and the parts should be fairly easy to do, too.
Two questions after reading your link:
1. What did you actually mount the compressor to? Did you drill holes through the fender well? It also looks like the regular ExtremeAire will be too long there so some bracket is needed -- the Junior may fit since it's only 10" long.
2. Did you mount the start switch inside the cab (one of the blanks to the left of the steering column) or just put it under the hood?
Thanks for the help -- I'm building the case for Santa to be nice to me. :D
Then again, I'm torn on which is better -- the Junior with a 2-gallon tank is probably all that I would need, because I can use the compressor in the garage to run air tools -- but 4 cfm vs. 1.5 cfm for less than double the price is awesome!
The mounting of it fits directly where I mounted mine. I did have to drill some holes and pick up some washers/nuts/screws from the local Home Depot though. (not a big deal)
When I got my extremeaire, they didn't have the junior so ... But all I can say is it's one dope air compressor :) Fits perfectly (nice and tight).
The switch is located in the dash right by the left side of the steering column as you state. Easy to wire up too so even a rookie can get this to work.
Lance -
Did you ever install an air tank? I was looking at places for one (2 gallon is the smallest I have found so far), and the only places I could come up with were in front of the radiator (put a couple of bars to link the bumper to the brace in front of the radiator) or behind the running board.
Since I want to keep the spare, there is no room under there.
You find another place?
I don't have a tank yet and as of right now I'm not sure if I"m gonna get one for awhile. I've used the compressor for airing up only currently so there's really no need for the tank.
But if I were to get one, I'd prob say I'd be storing it in the front with my new steel bumper eventually though (in time...).
I thought about putting on in the rear (spare tire area) but I decided not to as I'd like to get a custom rear bumper and a tire carrier and have Downey create a custom secondary gas tank there :)
So this really only leaves me with storing the tank in the front. There's plenty of room there so that's probably where I'll end up putting it (if and when.... one of the last things on my list).
Viair 450c 100% duty cycle... one of the best mods Ive done... that and the 2.5gal air tank that I use with it to operate my ARB air locker.
