BTO
Member
If your brake's hydraulic system failed and you had to stop your 4R with the e-brake, would it stop it?
I ask because I don't think the rear brakes on this 4R of ours work worth a damn. I have replace the shoes and turned the drums with no improvement. I replace the brake fluid too (that really has nothing to do with a basic lack of friction between the shoes and drums but I thought I'd throw that in). I am using AZ Duralast shoes. Could that be the problem? Crappy shoes?
It all looks to be working properly. Everything moves exactly as it should when using the e-brake lever or the brake pedal. Just not much stopping force. I thought the rear brakes were supposed to be self assisting. That is, the friction itself causes the brake shoes to engage even harder and that why the springs are used to help make them release. It seems I'm getting no self assisting at all.
This is a major safety hazard. I don't think the 4R has enough braking power to lock up the wheels even if you slam on the brakes as hard as you can. I believe this is due to the fact that the rear brakes aren't helping. It's all on the fronts and that one of the reason the fronts warp so fast, they have to do all the work! My girlfriend (who is the primary driver) thought it was the anti-lock system that was keep the brakes from locking. I told her that no, it's simply because they suck so bad.
