Options for grille hardware that's jacked?
Wile Kyote
So salt has been pretty murderous on vehicles. I wanted to swap out my grille and bug deflector with the grille from TEQ customs and a hood protector and what should be a simple and fun job turned into every 10mm bolt and stud being royally jacked. Even wd40 doesn't seem to help. Am I still able to get these bolts and studs? What can I do about the bracket the grille mounts to? Any aftermarket solutions or will I need the dealership involved? Oof!
Were you able to get any of the bolts out? I was able get most of them, but had to cut through / just rip the rest. Just keep trying lubricants and heat to see if you can get them to loosen
No dice. I've stopped for now because they all go to snap city. They look like they are giving and then the darn things just snap. Pretty lame. I wouldn't mind buying new ones, but then have to consider the grille frame as well. Kind of wish we didn't dump salt on the roads like we do here.
I have replaced 3 grilles on my 4th gen 4runners. I live in the Salt and calcium chloride belt too. None of mine came off w/o breaking through the plastic. Nothing worked because of the type of nuts toyota used.
Just a tip, if you get a new grille, use anti size on the studs. Never had an issue since.
Good to know! I figure I could use some stainless steel ones from the store if I match them up good enough, but for now I just bit the bullet and ordered some from the dealership. 8 total, like 2.60 a stud, and just under a dollar for the nut. They also want $72 for a new latch if I want to replace mine. As for the metal frame, I hope mine comes off because that seems to be a no go on ordering. Darn salt!
Jkmazon
