StreetCreeper
...The Owner's Manual you've got shows to only replace every 5,000 miles with dino oil. I'm not sure if synthetic was widely available in the late 90's, but it goes much longer. I'm over 10k miles on my synthetic right now but it's about due for a change, I run AMSOIL's high-performance oil since it's made for boosted engines and has a 15k mile change interval.
Your oil might be good for 15k but is your filter going to still be efficient after that many miles? Or do you change out filters on your way to 15k?
Just seems to me that even if the oil is still functioning as intended and the additive pack has not been depleted at 10-15k miles — your oil is still going to be full of crap with everything from unburnt combustion particulates to abrasive wear material if the oil filter is mostly full or worse blocked and in bypass mode.
While it may be overkill, I'm now running full synthetic with a bigger D3 filter every 5k. Having clean oil and a new filter every 5k just makes me feel all warm & fuzzy inside. I'm poor but I don't mind spending $45 on my oil and filters each time even at the miles I drive which means an oil change every couple months or so.
