ORW Now Offers Dirt King Fabrication
Dirt King Fabrication offers a wide variety of products for most makes and models. All of our products are held to the highest standards with quality setting us apart from the rest. Our goal is to manufacture such products for both the average off road enthusiast and professional racers.​
Bushing Upper Control Arms
Overview:
There are multiple issues when lifting your vehicle with stock upper control arms. Both the geometry and strength are compromised due to over articulating the UCA’s. We solved these problems by designing our arms with increased castor and repositioned pivot angles reducing stress on the joints. The increased castor allows for proper alignment and improved handling. We have also replaced the weak factory ball joints with 1” stainless steel uniballs for maximum strength along with increased articulation. For the inner pivots we used durable urethane bushings with zerk fittings for easy servicing. To mount the arms to the spindle we include high grade 17-4 stainless steel misalignment spacers and grade 8 hardware. All of the components on our upper control arms are rebuild-able or replaceable to make this product last a lifetime. The arms come pre-assembled and include detailed instructions for easy installation.
• CAD designed upper control arms Maximum wheel backspacing: 4.75" Vehicle must be aligned after installation
• Urethane bushings 2WD and 4WD compatible Appointments must be made in advance
• Grease fittings for easy servicing Works with factory or aftermarket coilovers
• FK 1" stainless steel uniballs
• 17-4 stainless steel misalignment spacers
• Zinc plated bushing washers
• Grade 8 mounting hardware
• Brushed stainless steel logo plates
• Durable black powder coated finish
Retail $699.00
Item #: DK-811902
Dirt King Fabrications Heimed Upper Control Arms
Overview:
There are multiple issues when lifting your vehicle with stock upper control arms. Both the geometry and strength are compromised due to over articulating the UCA’s. We solved these problems by designing our arms with increased castor and repositioned pivot angles reducing stress on the joints. The increased castor allows for proper alignment and improved handling. We have also replaced the weak factory ball joints with 1” stainless steel uniballs for maximum strength along with increased articulation. For the inner pivots we used heavy duty FK heims for additional adjustability in the arm. To mount the arms to the spindle we include high grade 17-4 stainless steel misalignment spacers and grade 8 hardware. All of the components on our upper control arms are rebuild-able or replaceable to make this product last a lifetime. The arms come preassembled and include detailed instructions for easy installation.
• FK 3/4" heims 2WD and 4WD compatible Appointments must be made in advance
• FK 1" stainless steel uniballs Works with factory or aftermarket coilovers
• 17-4 stainless steel misalignment spacers Major adjustability for vehicles with alignment issues.
Price: $749.00
Item #: DK-811903
Compatibility:
Toyota Tacoma 2WD/4WD 2005-Current (6 lug)
Toyota FJ-Cruiser 2WD/4WD 2007-Current
Toyota 4Runner 2WD/4WD 2003-Current
Toyota Hilux 2WD/4WD 2005-Current
Toyota Prado 120 2WD/4WD 2003-2009
Toyota Prado 150 2WD/4WD 2009-Current
Lexus GX 470 2WD/4WD 2003-2009
Lexus GX 460 2WD/4WD 2010-Current
Dirt King Fabrication Performance Lower Control Arms
Overview:
The Dirt King performance lower control arms are remarkably stronger compared to the factory lower arms. We replaced the weak factory ball joints with FK 1" stainless steel uniballs for strength and additional articulation. To attach the lower arm to the spindle we include high grade 17-4 stainless steel misalignment spacers with grade 8 mounting hardware. For the inner pivots we replaced the soft factory bushings with our custom machined delrin bushings. There are several major advantages of using delrin bushings compared to the softer bushings such as stock and polyurethane. The delrin bushings eliminate forward and backward movement of the lower arm, allow for a freer range of upward and downward motion unlike the injected factory bushings, and have a much longer life span than the competition. The arms are CAD engineered with a complete boxed plate construction and weight saving internally ribbed design. They are also tabbed to accommodate for bump stops and limit straps to be used if you choose. All of these components come together to provide a reliable and smooth ride both on and off road. The arms come fully assembled and include detailed instructions for easy installation.
Includes:
Boxed lower control arms
• FK stainless steel 1" uniballs
• Tabbed with bump stop plates & limit strap tabs
• Delrin bushings with servicable grease fittings
Custom machined grade 8 mounting bolts
Factory bump stop spacers to correcty limit up travel Additional Notes:
Complete bolt on, no modifications required
Does not increase the vehicle's track width
Works with the factory swaybar
• Additional welding backside of the factory
lower arm alignment cams. This prevents them
from folding over and throwing the vehicle out
of alignment.
Compatibility:
Toyota Tacoma 2WD/4WD 2016-Current (6 lug)
Toyota FJ-Cruiser 2WD/4WD 2010-Current
Toyota 4Runner 2WD/4WD 2010-Current
Retail $1,499.00
Item #: DK-813904
Please inquire by PM, or Email on Pricing for Special "T4R" Discounts for Dirt King Fabrication.​
