ORW & Rigid Industries D-SS Dually Side Shooter / CBI Ditch Brackets Combo
One of Rigid’s most versatile, compact lighting solutions just got better with the D-SS, Dually Side Shooter LED cube. Perfect for any application that requires a wide spread beam, including A-Pillars, Fog Lights, and motorcycle applications. The D-SS cube incorporates the same powerful optics and legendary LED technology as Rigid’s popular D-Series lights but with the added benefit of additional LEDs aimed to the side for a much broader beam. The D-SS fixtures boast up to 120-degrees of horizontal lighting coverage when used in pairs or when used in the single light applications. The main forward-facing LEDs are available with Rigid’s advanced Flood, Spot, or Driving optics, so there’s a D-SS lighting solution for nearly any application. The D-SS LED lights are available in pairs with three side-shooting LEDs on one side of each fixture, or in single applications with a pair of side-shooting LEDs on both sides of the fixture. Only Rigid provides a broad, powerful lighting solution in such a compact package.
Features:
Up to 50,000+ Hour Lifespan
IP68 Compliant
Impact Resistant Lens
GORE® Pressure Equalizing Vent
Harness & Switch Included
Mounting Brackets Included
Specifications:
Watts: 24
Amp Draw: 1.7
LED's: 7
Raw Lumens: 2425
Lux @ 10m: 42
Beam Distance: 65 m
Peak Beam Intensity: 4241 cd
Rigid D-SS Dually Driving​
Rigid D-SS Dually DRIVING SPECS:
Features:
IP68 Compliant
Specifications:
Watts: 24
Amp Draw: 2.3
LED's: 9
Raw Lumens: 3308
Lux @ 10m: 181
Beam Distance: 134 m
Peak Beam Intensity: 18066 cd
Rigid D-SS Dually are available in PAIRS:
Flood # SKU: 26211 Price: $299.99
Spot # SKU: 26221 Price: $299.99
Driving # SKU: 26231 Retail Price: $479.99
Also Available in WHITE:
White FLOOD #SKU: 86211 Retail Price: $299.99
White SPOT #SKU: 86221 Retail Price: $299.99
White Driving #SKU: 86231 Retail Price: $479.99
The fun doesn't stop there.... www.OffRoadWarehouse.com Creates a "COMBO KIT" that makes your install easier!!​
logo.png~original
CBI Off Road Fab T4R3 Ditch Light Brackets
CBI Off Road Fab 4th gen 4Runner Ditch Light Brackets
CBI Off Road Fab 5th gen Ditch Light Brackets
ORW Special Pricing, Choose... Rigid D-SS Dually Black or White / Spot or Flood and which CBI Bracket for your Gen.3/4/5 for $289.99/shipped
OR
Rigid DRIVING D-SS Dually Black or White and which CBI Bracket for your Gen.3/4/5 for $419.99/shipped​
Please send PM, or email [email protected]​
Rigid Industries
This LED Grille presented by Rigid Industries is specifically designed for the 2014-2016 Toyota 4Runner and allows for a clean, OE-quality install of Rigid Industries' high output lighting (not included). The grille accepts (1) 20’’E-Series light bar, perfect for the new Amber/White E-Series light bar. This 2-piece grille is made from laser-cut 304 stainless steel and is assembled using stainless steel button socket head bolts and nyloc nuts - no welds. It features a high quality black powder-coat finish. Installation requires modification to your OEM grille shell. We recommend professional installation. All hardware and instructions are provided within the kit.
Features:
  • Aggressive Rigid Styling
  • Stainless Steel Construction
  • Black Powder Coat Finish
  • Includes All Necessary Hardware
  • Limited Lifetime Warranty
  • Made in the USA!
Rigid Industries Part #40596
Fits: 2014-2016 Toyota 4Runner Grille
Retail $599.99
Please PM, or [email protected] for T4R Pricing!
A NICE compliment is the OffRoadWarehouse COMBO Kit Rigid Industries Fog Light Brackets & Rigid DOT/SAE Compliant Fog Light Set . This cleans up your front end and makes night driving much better.
Works for 2014-2016 Toyota 4Runner. Made with 304 Stainless Steel. Features Cardinal BK-59 corrosion/scratch resistant powder coat. LED Light sold separately.
*Does not fit the Limited Edition
Features:
  • Made in the USA!
SAE Compliant Fog Light Set (D-Series) #50481
Features:
  • Fog Light is Compliant with SAE J583
Specifications:
  • Watts: 33
  • Amp Draw: 2.29
  • LED's: 4
  • Raw Lumens: 1760
  • Lux @ 10m: 106
  • Beam Distance: 103 m
  • Peak Beam Intensity: 10570 cd
Rigid Industries
#50481 DOT Fog Light Kit retail $279.99
#46540 Light bracket kit $69.99
Retail Total is $349.98
Please PM, or [email protected] for T4R Pricing!!
Description:
Rigid Industries' SAE Compliant Dually Fog Light Set allow Rigid Industries LED Lights to be used on-the-road and not just off-road. Rigid created the perfect output spread and height achieved by the new patented Clarilux™ optic system. The color temperature of the LEDs is a perfect range of pure daylight to penetrate the night as your eyes read the road. The SAE Compliant lights project long range high intensity light while drawing very little power and provide up to 50,000 useful hours. The low profile design, advanced engineered heat sink, cast aluminum durability and the highest quality of strength of a polycarbonate lens is the ultimate solution for your street-legal needs in North America.
SAE Compliant Lights - Rigid Industries' SAE Compliant lights include the Dually Fog light Set and the 6” E-Series Auxiliary High Beam Driving Light Set. These SAE Compliant lights allow Rigid Industries LED Lights to be used on-the-road and not just off-road.
SAE Defined - SAE stands for Society of Automotive Engineers. SAE is comprised of a number of working groups of automotive and lighting engineers that work with industry studies and other experts to set standards. SAE sets the standards for pretty much everything on a vehicle, from how bright or dim a brake light can be, to lens coatings (in some cases) to thermal performance, to colour specification (is that red brake light really red, or more pink-ish?). While SAE is not law in most areas, it is a best-practices standard that the entire automotive world pays attention to. Comparing SAE numbers usually gives a good level-playing-field comparison between lights. SAE publishes thousands of standards, each one numbered. Within each standard, there are usually “Classes” that specify performance. When a vendor says “SAE Compliant” on their website or literature, they should also specify the Standard number and the Class. Without it the term “SAE compliant” is meaningless. Rigid Industries SAE Compliant Dually Fog Light Set follows the SAE J583 Class and the Rigid Industries SAE Compliant Auxiliary High Bean Driving Light Set follows the SAE J581Class.
Can't forget about the LIMITED 4Runners​
This Rigid Industries Complete LED Grille Kit is designed specifically for the 2010-2013 Toyota 4-Runner and allows for a clean, OE-quality install of Rigid Industries high output lighting. The upper grille accepts one (1) 20" SR-Series LED light bar and the lower accepts two (2) D-Series LED Lights (lights not included). These 2-piece grilles are made from laser-cut 304 stainless steel and are assembled using stainless steel button socket head bolts and nyloc nuts - no welds. It features a high quality black powder-coat finish. Installation requires modification to your OEM grille shell. We recommend professional installation.
Features:
  • Made in the USA!
Toyota 4-Runner LED Grille Kit
Finish Color:
Black
Fitment: Toyota 4-Runner 2010-2013
Shipping Dimensions:
17 × 36 × 7 in
SKU: 40556
Retail $649.99
The Upper Grill Fits a Rigid Industries SR-20" - Combo
The Lower Grill Fits ANY Dually Lights, Choose from DOT/SAE, Flood, SPOT, or HD D2.
Features:
  • Patented Hybrid Optics
  • Spot / Flood Combo
  • 50,000+ Hr LED Lifespan
  • Instant On / Off - No Warm Up
  • RoHS Compliant
  • Over / Under Voltage Protection
  • Extruded Aluminum Housing
  • Durable Polycarbonate Lens
  • Integrated Thermal Management
  • GORE® Pressure Equalizing Vent
  • Designed, Engineered, &
  • Assembled in the USA
Specifications:
  • Watts: 75.9
  • Amp Draw: 5.5
  • LED's: 20
  • Raw Lumens: 7500
  • Lux @ 10m: 1750
  • Beam Distance: 837 m
  • Peak Beam Intensity: 175000 cd
Let ORW OffRoadWarehouse build you a Rigid Industries Grill/Lighting COMBO
Please PM, or [email protected] for T4R Combo Deal.
Description:
Low Profile - The Rigid Industries SR-Series (single row) Light Bar, like our flagship E-Series, leads the industry in low profile performance LED lighting. Available in a wide range of lengths and configurations, the SR-Series light bar is the perfect low-profile option for everything from on and off-road racing to police and fire rescue vehicles to marine applications. The SR-Series light bar is designed to project light at extreme distances while consuming very little power. Its durable extruded aluminum housing and virtually unbreakable polycarbonate lens are sealed against the elements for years of trouble-free operation.
Hybrid Optics - Our patented Hybrid optics system is the most powerful, most efficient LED optics system on the market. Utilizing a combination of lens and reflector, the Hybrid optics system captures the maximum amount of light emitted from the LED and projects it exactly where you want it.
Spot / Flood Combo - This Rigid Industries light features a combination of both Spot and Flood versions of our patented Hybrid optics system. Our Hybrid Spot optic projects light over great distances in a concentrated beam and is the most powerful spot-style LED light in the industry. This makes it perfect for high speeds and situations where you need extreme distance. Our Hybrid Flood optic, while offering just over half the distance of the Spot version, provides twice the coverage area. When combined, The Hybrid Spot and Flood optics provide the perfect combination of both distance and area.
Quality Construction - Our circuitry is designed in-house to be more powerful, be more efficient, and generate less heat. Our durable aluminum housings feature custom, over-sized heat sinks which keep the temperature down and allow our LED's to run cooler and brighter. All Rigid Industries LED lights receive a high quality powder coat finish, a custom-molded rubber seal, and an unbreakable, scratch resistant lens. Rigid Industries LED lights are engineered to withstand whatever you, the road, or nature can throw at them.
Contact your local dealer / distributor for more information about this and other high quality LED lighting products and accessories from Rigid Industries LED Lighting.
Kit Includes: Plug and Play Harness with Switch as well as Mounting bracket and hardware.
workingwheelswnc
