OUTRUN's Bumper Build
OUTRUN
After receiving all the likes in the "what did you do to your 3 Gen today" thread I think many of you would like to see the progress on the rear bumper I am doing.
Quickly about me because I am new. Ive been big into Nissan cars for the longest time ( See Skyline Build Here : //Running in the 90s// R32 GTS-T Revival - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum) But over the winter my close friend took me out for a little off roading in his 3rd Gen and I was hooked.
After watching him fab up his front bumper (lots of one off manual tube bending) and doing a bit of research on the type of things people do with these trucks I offered to help him design a bumper for the rear of the truck.
I am a mechanical designer by trade and use CAD daily to design enclosures for machines at work.
Naturally we got to work on a cardboard mockup.
The idea was to design around having it able to accept a swing out in the future and be a fully bolt on part. I found many of the plate bumper designs out there to be very bulky and visually heavy looking so we tried to keep things as slim as possible (also helping out with approach and departure angles)
From there we went ahead an extensively measured the truck. These measurements were used to create a model in solidworks to build around.
This helped helped getting the bumper to "fit" the truck but I knew we could get it fitting better if we were able to somehow get a scan of the truck. After some researching and digging I was able to use an old Xbox Kinect to scan the back half of the truck.
This was the end result of my very amateur 3d scan. It wont give me hole locations or anything that detailed but it is to scale and works wonders for creating a base to follow the lines of the truck.
Here is a snapshot of the bumper "mounted" on the 3d scan to verify fitment. then it was off to the laser cutter to be cut from 3/16 plate
We wasted no time fitting it all up and tacking it together.
Fitment with the tailgate closed is spot on
I realized after the parts were cut that the scan was done with the truck on the hoist. This meant that the suspension was drooped and I made the side a bit to long. I hope to have those pieces back from their date with the metal shop later today. So far I love how the bumper looks.
I will post up more progress as it happens.
Thanks for reading
- Jordie
Would you be willing to sell the file to take to a shop to have the pieces cut out so that we could build this bumper at home?
The scanning using a kinect is genius! Im also a designer and use Solidworks on the daily. We have a FARO Arm (not the laser scanner though...) but a kinect price tag is cheap compared to $100k+. Definitely going to look into that for making a rear bumper myself. Would you mind sending me the link(s) that you used to make it all work?
Excellent work on yours, turned out awesome!
Beautiful work!
[emoji1374]
Great design [emoji1360]
Thanks!
You may have already considered this but be aware of body flex, you may want to buy/diy some rear body mounts: Rear 4Runner Polyurethane Body Mounts (Pair) - $75.00 : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
Thanks for the insight. We will have to see how this first one works and put it through a battery of tests to see where the problem areas are and adjust the design as necessary. but Poly body mounts wouldnt be a bad idea seeing as the truck has 412 000kms
Perhaps further down the road once all the issues are worked out. We have a couple local guys who are interested in them as well so we will be tweaking the design after testing and perhaps doing another run of parts.
Unfortunately I do not have any good photos of the underside or how it mounts to the frame. The design uses the stock 4 mounting locations on the frame and has mounting holes to allow bolts to go though the frame if desired.
I picked up the side pieces after having them modified and will swing by the shop to continue work on the bumper tonight. I had an alignment booked for an upcoming track day last night.
Too many projects I know....
Wow that bumper is looking awesome already! I'm looking forward to seeing the finished product!
Thanks, We finished the bulk of it off this evening and got the side plates welded up. There are some areas which need addressing should we ever make another one.
As previously mentioned the gap around where the bumper meets the quarter panel (below the light) needs to be opened up a bit to allow chassis/ body flex.
As we do not have direct access to a bender capable of bending 3/16 plate, panels were "slotted" with tabs so they could be bent easily and seam welded afterwards. This was a necessary evil as it allowed us to fine tune the panels to the truck but the heat caused some distortion when we welded them up. This also created some gaps which needed filling.
We also angled the side "wings" out a bit to match up with the limited flairs which will eventually be added to the truck as the 35s stick out a bit
All in all it went together relatively easily given it was our first kick at the can. We still need to grind everything down/ clean up the welds, mount the receiver hitch as well as the shackle mounts and get it coated.
Overall Im happy how its progressing. On to the pictures.
Seriously one of the best looking rear bumpers I have seen...
Thanks!, Im just happy to finally (sortof) use my automotive / industrial design degree for something other than regular work :P
Zilvians in da houseeeeeeee
I also follow you on IG lol
Oh Hey!. Small world, saw you got a truck on IG, looks nice. I'm looking to import a hilux now because everything in Canada is rusty or has 400 000kms
seltzernator
