Has anyone else experienced an overactive VSC? At times even when I'm just turning into a parking lot and the vehicle will pitch a bit- I will hear the beeping and my brakes will shutter. I have a 3'' OME lift and running 33's- and wondering if anyone else encountered this problem.
I like the idea of the VSC when driving on the road in normal conditions- but also plan on installing the bypass switch like I have seen some do on here for 4wheeling or snow driving.
Any input is appreciated.
Rather than create a new thread I'm going to revive this one a bit...
I'm running into what seems like the same situation as mentioned to start this thread. Since the Icon Stage 2 and 285/70/17's I seem to be encountering an oversensitive VSC.
Coming into corners at approx. 10-15 mph, usually with a slight uphill, I'm getting the beeping. I'm talking turns from roadways into raised parking lots, or parking lot sharp-ish corners, not roadway corners. Not drifting or spinning wheels here. (and the parking lots are empty early in the morning going into work).
Anyway, there isn't any noticeable braking or power loss, though I'm sure it's happening, it's just that these little happenings only last all of about 1/2 to 1 second tops.
Anyone know if this is just something I need to learn to live with unless I learn to reduce speed and thus body roll in slow-speed sharp turns? Or is something else going on?
Thanks in advance to any helpful hints or similar experiences. And thank you [MENTION=21749]r3dh3ad84[/MENTION] for giving me a place to start on researching this.
