Overdrive not used!!
alpinist
Bought an '05 with 12.5k miles on it and it now has 35k. Tonight I realized it has an overdrive gear which I've never used - wow - don't I feel like a dumbXXX. I can't imagine I've hurt anything as the truck runs great but any thoughts? Have I hurt the truck in any way? Also, are you guys shifting into overdrive for city driving?
Why do you think you were not in overdrive. When you put the shifter into "D", your in overdrive. To take it out of overdrive, you have to put it in "D" and then move the shift lever to the left to "4".
If that is indeed what you did then, you will be getting better mileage in the future. :D
thanks peter78 - ya, I was shifting into 4th, do you keep it in OD in town? - seems like this is what the manual is recommending I just don't want to be lugging the engine
Normally you leave it in D. It the transmission hunts, (going back and forth between gears), then shift to 4. The transmission is built for a truck it should be OK, 99% of the time to leave it in D.
As far as damage leaving in 4, I drive my 4Runner with the overdrive off when I tow. I think the biggest damage you have done, is your bankroll to pay gas, especially when it was $4 a gallon.
My 4th gen. 4Runner only has 4 gears and I drive mostly in town and it does not have a problem, it seems to shift pretty smartly and not seem to lug. You will just have to see how your rig does, when you finally put it in "D".
wow thats pretty dumb
I usually leave mine in '4' when driving around town. When out on the open road, I use 'D', except when I need to pass, then I drop it back into '4'.
Pressing the gas also does the same thing - why do you manually shift down?
eskimochaos said:
Pressing the gas also does the same thing - why...manually shift down?
Pressing the gas in 5th is not quite the same thing. Overall performance and response is better in 4th. For one thing, it will shift into 3rd faster from 4th than it will from 5th. If the passing conditions are tight, I sometimes go to third before I pass so I don't have to fade any shifting delay.
That's funny, and probably a little embarassing at the same time lol. The gearshift is like lower than the 101 class! Im not old but Im not young, and every Auto vehicle I've ever driven or seen since I knew much about vehicles, the "D" in the quadrant is what you shift to for most all driving. You only use the manual downshift if you are towing, or want to already be in a lower gear and have the RPM's up in anticipation of passing someone on a 2 lane road or getting ready to race lol. But otherwise just let the engineers design do it's job and just put it in Drive.
I personally just leave mine in D as the Automatic Transmission, with all it's sensors, are feeding into the ECM data along with the engine's parameters, to determine the appropriate gear for you. Hence the name, Automatic, does it all on it's own, you just have to mash the loud pedal down. Though in traffic around town, I have been known to leave it in 4th so that it does not hit OD, keeps the revs up a bit, and power at the ready in case some dipshit wants to try and run up and cut me off, I can close the hole up quickly and watch him writhe in anguish and flip me the bird. I love driving!!! :bigok:
My Ram, well, anything under 50 and I keep the OD off. Mine only has 4 gears, you choose from 1,2,D, and the OD is not a position on the shifter but rather an electronic switch. So instead of shifting out of OD like in the 4Runner, you press a button that says OD OFF and you're in 3rd or "D" on the quadrant. Press the button again, and it shifts into 4th which is also "D" on the quarant.
The 04 4Runner is the first car I had with a gated shifter. New to a gated shifter, I wasn't too keen on having it. It seem odd that you put it in D and to go to a lower gear, you move it to the left instead of down. What if the passenger hits it. Most cars you simply move the gear shift down to get to a lower gear, not move to the left.
After 3 months, I find it very natural and easy to use the gated shifter. I don't even look, I do it by feel. So now, the gated shifter is OK, not better, but not worse either.
My guess is, this was your first gated shifter too. Someone told me a story about when he borrowed a friend's motorcycle and he shifted into first, which is down on the knob with your foot. So, he shifted down again, instead of up. When he got back, he said he could get it much pass 40 as the engine was over revving. :happens: :jaw drop: :xnuts:
I manually downshift to 3rd. More fun and it gets there when I want it there. Wish it had egear as a matter of fact...
I tend to do the same when I know I'm going to have to romp it around someone. I guess this comes from only driving a manual before this auto.
