Overheating after head gaskets
DJRodriguez88
Moved from All Questions thread.
Just finished my head gaskets and the truck is running much better than before, smoother idle, no more hesitation, and no more white smoke. but I'm having some overheating issues. Doesn't overheat idling, only while driving. If I stop at a light or stop sign and raise revs in neutral the temp will go down a bit.
There's a new oem water pump, timing belt, thermostat and fan clutch.
I've burped the system using a no spill funnel while parked on a hill.
The only thing left I can think of is clogged coolant passage or I seriously fked something up doing the head gasket. But the car feels like it's running better than ever except for the overheating issue
What else could I be missing?? Would having the tstat jiggle valve in the wrong orientation cause this much of an issue?
I havent pressure test the cooling system or compression check yet, I guess that's next up.
The thermostat jiggle valve in the wrong orientation, which would be in the 12 o'clock position, will cause your engine to run approximately 10 degrees hotter. It's a decent difference, but not enough to cause the engine to overheat. A normally functioning cooling system on the 5VZ-FE engine will run between 188-192, but will go up depending on the ambient temps and driving conditions.
What temps are you seeing? Are you consuming any coolant?
I'll need to get a scan tool. I haven't been able to drive long/far enough to lose coolant as I see temps creeping up toward the red within a mile. When I first finished I was able to drive a couple miles (albeit down a mountain) without overheating, but it seems like as soon as I put any load on the engine at all it begins to overheat. Sometimes it'll come back down before reaching red (not sure what triggers that) but I have to be ready to pull over at any moment
Were the cylinder heads inspected/tested for cracks when the head gaskets were replaced? I would also check the oil to see if there are any signs of coolant in it. I'm guessing you either still have air in the system or something was missed during your headgasket repair.
Good luck and let us know what you find.
You say head gaskets so I'm assuming it's the V6.
Are you sure you put the left gasket on the left head and the right gasket on the right head?
OBDII-based temp reading is crucial info you need. You want to know where your temps stand more accurately than the "Cold, OK, and Disaster" the dash gauge provides. Is there action in your overflow jug? Is your coolant actually hot AF? Dash gauges can go crazy (fuel for example).
I see action in the overflow jug. Coolant goes into the overflow when hot. If i start it hours later when completely cool it gets sucked back up into the radiator.
When the engine gets hot and i turn it off i can hear a lot of boiling/bubbling/gurgling inside the radiator/hoses
It should suck back in on its own while the engine is off and cooling down - it shouldn't require the water pump to suck it back in. Cold to hot the overflow should go up and down maybe half the height of the overflow container.
-Charlie
Does your overflow always go back to the same cold level?
Generally three heat cycles with a properly operating rad cap should push all the air out of the system.
Not sure but thanks for that insight, i'll monitor that
I need to try and get the truck mobile so I can get back to my garage so I can figure this out. But my house is 25 miles away up a steep mountain so it'll take all day to limp there.
I want to try running without the thermostat and see if that'll get me home or at least to a shop.
The gasket/o-ring is on the thermostat so will the neck leak if I remove the thermostat?
BTW I got a scan tool so I'll grab some helpful data next time I'm with the car
One of my heads was visibly cracked so i sourced a junker which the machine shop inspected, pressure tested, and machined. One thing that got skipped out on is clearing the coolant jacket of the junker head which looked like the underside of an old boat.
I didnt know there was a left vs right! i just made sure that all the alignment dowels lined up and no holes/ports were covered. I would imagine that it would have more severe symptoms if they were backwards right? It can idle without overheating and drives as good as ever besides the overheating ofc
If you have an old thermostat around you could gut it and then you'd be able to use the oring.
Or, you could make a gasket out of paper type gasket material or even the right kind of thin cardboard.
There's various technique's, all of them easy and quick.
And to repeat what Tim said - when you figure this out and put in the final TStat, make sure the jiggle valve is down at 6 O'Clock. My temps dropped 13 degrees immediately after doing so. I had swapped in a new radiator and oriented the TStat the way the previous mechanic had....wrong.
You can literally put the heads or head gaskets on the wrong side. If the HG is on the wrong side it will block the coolant passages.
you could make a gasket out of paper type gasket material ... easy and quick.
Thanks again, I ended up doing this and it was indeed easy and quick. The most annoying part was draining the coolant and removing my dynamic tensioner (sits right in front of the thermostat housing)
to repeat what Tim said - make sure the jiggle valve is down at 6 O'Clock.
When i pulled my T-Stat out it was @ 6 O'Clock. I must've been watching Tim's vids or something =p
New OEM radiator cap too?
Good point! It's only about 2.5 years old so I hadn't considered it but it's not oem so maybe it's on its way out already? it looks good and feels good but idk how to tell if its good.
Update: after removing the T-Stat and going for a short test drive with the limited time I had with the car today...
The temp gauge sat at 25% (1/4 from the bottom) the entire time. Before pulling it out i got close to red within a mile.
What can I deduce from this observation?
I believe it's telling me that either the thermostat is bad (it's only like 2 years old 170 degree unit from URD) or, as I have been suspecting, there is some blockage not allowing coolant to flow freely. Also not totally abandoning the possibility that there is still air in the system or something (even though i filled/burped with a no-spill funnel)
What are my options for next steps?
Seems like maybe (in no particular order):
- a chemical flush to clear the potential blockage in the junkyard-sourced head.
- new T-Stat already???
- leakdown/compression tests
Also I got a new bluetooth scan tool so I'll be monitoring temps via Torque app from now on
I say try the new T-stat and rad cap and see what happens. Make sure you’re not sucking your lower rad hose flat. Also make sure your temp selector is on max heat to push any air trapped in the heater core into the rad.
Make sure your hose between the rad and overflow tank is not blocked and is tight on the barbs.
If your cooling system is operating properly the air should naturally purge into the expansion tank after around three drives.
Driving around, any air in the system will collect in the upper radiator tank.
When the engine cools off the rad caps vent valve relaxes. When you start the engine the water volume expends and that will push any air collected at the top of the rad into the expansion tank via the vent valve in the center of the cap. That valve is temperature sensitive. So when hot coolant starts going through the vent it closes to allow the cooling system to build pressure.
All three 3gen 4Runners I bought had a broken rad cap. I’ve had a Napa cap in my 97 for 3+ years without any issues. But, saying that everything is new. Engine, rad, etc.
erinobr2000
