Ow brake relocation bracket
Does anyone know if you can still get these?
no the company closed, however its a very simple bracket to make. I have one and can send you pictures. All it would take to make one is a strip of 11gauge or 1/8 steel about 1inch to 3/4" wide. a bench vise or hammer and a piece of wood to make the bends and a drill to punch some holes for mounting. the bracket could be made in just an a hour or so worth of labor.
lol there not hard to install, you just unbolt the bracket that holds the flexible brake lines leading to axle, gently bend the solid lines above the bracket towards the axle and down. insert bracket between factory mounting bracket and the just relocated brake line's mounting plate, bolt the new bracket to the factory bracket then bolt the retainer holding the flexible brake lines to the new drop bracket.
hope that made some kind of since lol
that give me a broad outline of what to start looking at down there lol. do you by chance have one?
yea i got one with the rear extended travel kit they had on sale durring there closeout. It's a way better solution than extending the brake lines them self no need for brake bleeding
could you maybe post a pic of it installed? that's would be all the instructions I need lol
