P-4 775 Heatsink reinstall
ran
Senior Member
Yes, I still keep this P4/800 PC up for games and such. Cheap CPUs out there now, got a 3.0/800 for less than $7.00 and installed, trying to get the square type Intel H/S back on is the problem. Almost ready to pull the mobo out, but I can see all around it. I can get 3 legs down, that's all. thanks all
Next day , I pulled it off and reinstalled in, same with Video card and used up all the canned air to clean things up. Boots fine (after that thermal shutdown) in Safe mood only. Updated utilities, trying for a full boot, may be too hot of a CPU --2.4--3.0?? still playing with it. 6 case fans should help. fun times
OK, if it can run fine 20+ minutes in safe mode, why not anything else? there is nothing that would govern that? strange.
Busy today, but if it runs 25+ minutes updating in Safe Mood, no reason that it should not run Windows. Tomorrow I will pop the 2.4 back in and test. Maybe this 3.0/800 was O/C or something. fun times, forgot how much fun the P4s were. The BIOS temp reads 46C/114F. but if Safe Mood runs, I can't see a reason why it doesn't work. fun
Pentium 4 ???
Not to sound like a hater but that seems a bit dated. Now as for myself I'm running a 2010 i7 970 6-core chip @ 3.7GHz but with 6 true cores at 3.7 it is actually a screamer! I have been thinking about upgrading and might do it once Intel sorts out this whole Meltdown & Spectre BS vulnerabilities.
More power to you with bringing that P4 back to life.
Here is what I suggest:
* Burn a linux OS to CD and boot from disc then run memory and CPU test utilities
My P4 is an old 2003 machine with a few 32 bit games. Right now I am on a ex business Quad Core i5 I have built up a little and went with Win 10.
back to why this 3.0 will not boot to Windows??? I will pull it and check pins, but how can a CPU be selective about how it boots????
Did you take my suggestion and run a test CD?
How about using the built in extended testing in the bios?
How about throwing the motherboard in a lake?
2.4 Ghz/800 back in and runs fine. I accept that is a bad chip. thanks all
I'm coming up on 64 yrs, I don't need anymore aggravation anymore.
turbomikee
