P0306 please help!!!
skorpion
Ok I know this is a topic previously discussed but everything is old Im looking to see if anyone has had this issue and found new solutions.
So truck started to idle and run rough. Just like others the truck woulod smooth out after running for a while.
I replaced the coil on number 3 cylinder which also controls the number 6. I replaced plugs, wires, seafoamed the truck. Put 93 octane fuel with fuel treatment and did a compression check on the cylinder.
The problem is still there, although intermittent but its there.
I was told it might be jumped timing or an injector. Does anyone have any suggestions where else to look.
Would a stuck EGR valve cause this problem.
PLEASE PLEASE HELP!!!!!
