I'm new to the site, not as experienced as most of you, but I'm learning. Here's the question: 1999 T4R, purchased used in PA, but it's a Cali vehicle, has 140K miles. It's been giving me the p0420 code - I've replaced both the upstream and downstream O2 sensors with Bosch (before I read you guys all say to use Denso - I'll get Denso next time). Anyway, the code still comes up. When I hook up the scan tool, I get a flat reading 640-650 mV on the upstream sensor and a fluctuating reading 250-550 mV on the downstream sensor - I think this is opposite of what it should be - makes me think I have two problems (1) a bad (new) Bosch upstream sensor since it's not fluctuating high and low and (2) bad catalytic converter(s) because the downstream sensor is fluctuating between high and low readings. Any thoughts would be greatly appreciated!
