P0505 code after valve gasket job
jeredcollins
Just replaced these items today:
Valve cover gaskets
Cam plugs
Half-moons
Plenum gaskets
PCV Valve and grommet
Throttle body gasket
NGK spark plugs
NGK cables
Started it up and it seems to be running fine minus the CEL. Ran a diagnostic test and it said P0505, IAC. I cleaned the throttle body and MAF sensor too as well. Not sure why I have an issue now. It’s idling steady at 1K RPMs. Maybe I’m being paranoid but it does feel like a very slight rough idle that comes and goes every other second. Need suggestions fellows.
Valve cover gaskets
Cam plugs
Half-moons
Plenum gaskets
NGK spark plugs
NGK cables
Just covering the basics, but you did plug it back in all the way right? Both the plug and the hose? That's a very uncommon code to have.
Embarrassingly, I accidentally forgot to plug in the harness. Still showed a CEL after that so I disconnected the negative battery terminal and reset the ECU. That solved my problem.
Haha, no worries, I figured that was the case. I've never heard of that code popping up, ever.
My IAC got finicky with a high idle after my valve cover job too. Probably because I cleaned everything too well. Try resetting the ECU to force it to relearn. Also, when the throttle body ages the clearances get looser so the butterfly doesn't shut as tight. I ended up putting a light spring on the throttle to help it close better and my idle has been normal since.
044runner4
