P1300 cel
Gerdo
My 4runner started just fine a day ago. After running for a couple of minutes, I started to back out of my driveway when it coughed and stalled. Later in the day (8 hours later) I tried to start it again. Still a no go. A few more hours later, it did start. Since it was running I started poking around the ignoter and then the coil packs. When I touched the wires (with a stick), it stalled again. After getting it running again, I poked again and it stalled again. At this point I removed the packs and cleaned the connectors. After re-assembly, I started and poked, it stalled again. It looks like it's just a broken wire at the connector. Time to hit the junkyard and splice on a new end.
I was going to say I hope it is not the fuel pump.
BTW, I am beginning to have the hard starting, so I may be in for a pump change in the not too distant future.
I too was hoping it wasn't the FP. Since it is fairly new and a Denso.
I did fix the issue today. I went to my local Toyota junkyard and looked thru a thousand or more connectors and did find THE one.
Once I cut out the old one, I noticed that half of the contact had broke off and was making a bad connection.
With the replacement in, it works great. I poked at it and it didn't even burp.
I love cheap fixes.
DJNutshell
