On a side note. I am in the process of painting the wheels off of a 2006 TRD Tacoma. Here is the one that I have done so far. The picture really does not do this wheel justice, I couldn't be happier with the results.
Things I bought:
-Duplicolor High Performance wheel coatings (AutoZone - $5.49)
-Duplicolor clear coating (AutoZone - $5.49)
-400 grit Wet or Dry sandpaper (AutoZone - $2.99)
Things I did:
-Sanded down each wheel as best I could with the sandpaper (dry sanded)
-Blew the wheels off with high pressure air hose. If you dont have access to this just wipe them down with a wet rag to get everything off.
-Then I did 3 very light coats of paint and one final medium-heavy coat. Wait 10 minutes in between coats. After the wheels are painted then do the same procedure with the clear coat and let them dry overnight.
From what I understnad, the Duplicolor wheel paint is very durable. I dunno about using regular duty clear though. It may start to chip or flake. Did you use a wheel coating clear?
I used the wheel coating clear coat that is supposed to be used with the Duplicolor wheel coatings. It seems to be a durable paint job, but only time will tell. I actually got all 4 of them done now. Hopefully will be installed next week. I'm getting them installed for free which means I gotta be patient...
