pairing the right amp with the right sub
GottaBeTRD
Hey guys, sorry for dumb question, but i need to pick some of ya'lls brains. So, most of your audio guru's know i posted the thread about my sub/cargo box i've been building. I got a ton of good info on everything, but decided to go the budget route and stick with my original plan.
Anyway on to the question, I just ordered this sub and am wondering if it will work with the amp I currently have? I've tried a search but i really didn't know how to search for this lol!
Sub I didn't pay this price It's much cheaper on Amazon
Pioneer TS-SWX251 Compact sealed enclosure with one 10" shallow-mount sub at Crutchfield.com
sealed enclosure with one 10" subwoofer
5/8" medium density fiberboard construction
4-ohm total impedance
power handling: 50-200 watts RMS (800 watts peak power)
frequency response: 20-114 Hz
sensitivity: 91 dB
18-7/8"W x 11-15/16"H x 5-7/8"D
my dinosaur amp
Pyle - PLA2200 - 2 Channel 1400 Watt Bridgeable Mosfet Amplifier
00 Watts x 2 Output
1400 watts x 1 Bridged Output
Variable Hi/Lo Electronic Crossover Network
Variable Input Level ( Gain ) Control
Switchable Bass Boost
Power And Protection LED Indicators
Low Level Inputs
RCA Inputs Outputs
Slim Size Amplifier Design For Easy Installation
Thermal / Overload / Short Circuit Protection
Anti-Thump Turn-on
Soft Turn-On Circuit
Remote Turn On/Off
S/N Ratio: 95db
T.H.D: 0.04%
2x10 Amp Maxi Type Fuse
Freq. Response: 15Hz - 30KHz
Dimensions: 10.63'' H x 1.42'' W x 8.75'' L
Should work out fine, The manual to the amp says Bridge power 4 output 160 Wattsx1. I'm assuming that's 4 ohms.
cool thanks! I was watching some videos on Youtube and it mentioned as long as my RMS power on the amp is more than what the sub is rated at It will be good. It's just my amp is so old, i think the RMS rating is different from the newer ones. I figure its was already powering a 12, so I cant imagine it being bad for a 10.
But then again all this new stuff and I want it!
