Panhard bar bushings?
Older thread but I'm reviving it. After replacing my bent phb with a used straight one I got from a member here, I've been getting some clunking from it. It didn't start immediately, but a friend and I diagnosed the sound yesterday. It's been going on for a week or so. It's the driver side end. Driving me nuts! It only makes the noise with selective movements, rocking back and forth usually creates it, so for instance anytime I drive over a curb on a driveway causes it. Wondering if I can find some poly bushings for it, or if I flip it around it will go away. Anyone ever source some poly bushings?
I had the exact same thing going on after I did my rear axle swap. IIRC on of the mount bolts was loose. I loctited it back in there good and tight and it hasn't don it since. I figured the noise came from the bushing inner core sliding back and forth and hitting the bolt a bit as I turned or hit bumps. I still have my bent PHB in there and my straight one on a shelf... I should swap that out this summer.
BTW, I think I was able to get under the back end and shove the body side to side and see a bit of movement in one of the bushings. You might try that to confirm, though you may not be able to shove it hard enough to get it to move.
We did do a bit of testing to figure out what the noise was. After sticking a pry bar under the phb and prying against it while moving the truck the noise stopped. This was our clear indication. When replacing it (which for some reason was a pita) I tightened the bolts with my cordless impact. So there is no way it's loose. I dunno, I guess I'll hit it again with the impact and see what happens. The bushings do look worn however, which is why I'm also wondering about poly bushings. I doubt anyone makes a kit specifically for it but may be able to find bushing that fit.
I've looked around and I can't find a bushing for a third gen. I can find them for second and 4th gens but not a third for some reason. I have the same problem, my drivers side bushing has all but fallen apart and clunks around. I am probably just going to make a new panhard with my own bushings to fix it
2001ATL
