Panhard Correction Kit install - Shout Out to @eimkeith
DaMonkey
Just put in the axle side Panhard Correction Kit that I received from member eimkeith.
I have to say that this is probably the best possible fitting piece I could have expected. It sits in perfectly and welded up nicely. Very impressed, and happy to correct something that was kinda bugging me...
The kit comes with both sides if you need more correction, but I only needed to install the axle side with OME 906 springs, and my panhard lays flat on it's own weight. Very happy with the bracket and correction, thanks Keith.
Thanks for bringing this up.
I have 2 inch height difference between left (17 inches center of the bolt to ground) and right side (19 inches). Would this cab cause a slight pull to the right? I see you have a slight incline as well. How many inches do you have? I got 99 tall springs installed.
I think any actual pull it causes (like a bad alignment pull) would be negligible, but it does sit the axle a bit biased to the passenger side, so it's like a crab (also negligible at our lift amount). But mostly what is going on is that on further droop it pulls quicker and further to psgr side so the tail starts wagging the dog on dips on the hwy. The bigger lifts are more extreme, but you can definitely feel it with 2" difference.
Pretty sure 99 talls are similar height to OME 906 on an empty truck? Maybe just a bit shorter, but 2" was my panhard difference, so sounds similar.
Thanks man, looks great!
Agreed! I just got mine on today and woah what a difference. Corrects that rear end up nicely.
Sent from my Pixel 2 XL using Tapatalk
seltzernator
