part# for rear wheel stud / Matrix AWD wheel stud compatibility with OEM wheels
jdm-v35
Member
Does anyone happen to have the part# for the rear wheel stud? or an ARP/stronger than OEM equivalent would be even better but length still able to fit the OEM wheels/lug nuts for when I put snow tires on OEM wheels.
I am not sure if the matrix AWD studs are too long for the oem lug nuts or not since I do not see anyone using them with OEM wheels.
I put some aftermarket wheels on and only getting 6 full turns of lug nut engagement in front so looking to install longer rear studs in front for some extra safety.
Tried looking around but only saw the part# for the awd matrix studs. I would change them all to the matrix studs if they are not too long for OEM wheels/lug nuts. not sure if anyone is using that combo.
Thanks in advance.
I’m using the AWD matrix studs on my front aftermarket wheels, not OEM lug nuts. I will see if I can find the part number.
Thanks! I saw the dorman part# for it but not an OEM part#. Do you think they would fit the OEM lug nuts? I plan to put snow tires on the oem trail wheels using OEM lug nuts so I just want to make sure the matrix lugs would not be too long.
Ambrose67
