Part wanted... thought I'd check here as a last resort
Hi Guys,
Last check before I go with plan B.
I'm after the vehicle side plugs that power the lights in illuminated mirror sun visors... I finally managed to get a couple of the visors from Japan, but they came without the other side of the wiring loom.
If anyone has a breaker and could supply them, with an inch or so of cable I can connect too, that would be amazing.
Otherwise I'll just do the "sensible" thing and replace both sides with a more obtainable connector.
Hi Guys,
I may have a couple laying around, I'll check this evening and get back to you.
Thanks Leon,
I'm looking for the opposite part to these:
Charlie.
Yup, understood, you want the body side. I might have them, I'll check tonight. Depending on what your Plan B is, I'm also planning a junkyard run soon and can see if I can grab these for you there.
Thanks..
Plan B is cut off the existing connector saving as much wire as possible and replace the connectors with something more generic ad Locally source able.
However I like keeping things factory where I can... err, even if they are from someone else's factory on a different spec truck.
I "assumed" that DeathCougar took care of it? I'll be hitting a junkyard within a few days, I can certainly grab a pair for you if I see them. Let me know.
Yes please.
Alas I have never seen a late 3rd gen in the UK, let alone one in a junkyard!
I tried looking for suitable connectors today for a more local solution, but all the two pin connectors are either for tiny current, or too big.
Sorry for the delay, been dealing with a sick doggo.
I have the connectors, they have to be sourced from two different trucks as the US market 99-00 limited only uses a light in the pass side.
$25+ship to cut up two good wiring harnesses.
PRWhite
