Parting out 01 4Runner (AT,4x4,SR5,78K) - Northern Colorado
mussy01
*******ITEM LIST BELOW UPDATED AS OF 7-23-2013. Went through my items completely and these are the only things I have left. If it's not on the list I do not have it. If you'd like pics of anything just let me know and I'll post or PM them ********
Hi all,
I am located in the Fort Collins, CO area and am beginning to part out a 2001 4Runner that I purchased for a 3.4L swap. A bit of background on the vehicle to start. It was a SR5 model with an auto tranny, 4x4, and 78K on the odometer before it was in a rollover that damaged the driver’s side body and bent the rear axle. I picked it up in Kansas City and towed it to CO, but the vehicle started just fine and I was able to drive it into the garage despite the bent rear axle. At this stage in the game the vehicle has been completed stripped and the carcass has been sent to the junkyard.
The following list is what I have available as of today. I will use this first post to update when items have been sold. The prices listed do not include shipping so please include a zip code in your PM for items you’re interested in. I will not ship items like the AT, doors, or sunroof. I will accept paypal, cash, or bank checks, and once payment is received I will quickly get the items shipped. Prices are negotiable so feel free to let me know what you’re interested in and we’ll go from there. I also have a few items from a 93’ 4Runner w/ 3.0 if you’re interested.
Pics can be found here: (link to the top folder; drill down to sub-folders on the left of the page)
http://s1285.beta.photobucket.com/us...yota 4Runner
- Rear Upper Control Arms - $20
- Rear Stabilizer Bar - $20
- Rear Lateral Control Rod - $20
- Front Brake Calipers $20
- Radiator $50
- Coolant overflow resevoir $15
- AC Condensor $40
- Fan $30
- Fan clutch $25
- Fan Shroud $20
- Hood Hinges (2) $10
- Auto Transmission & T-case $750
- Lower Transmission Inspcection Cover - $15
- Transmission Cooler $40
- Transmission & 4WD Shifter Assy SOLD
- Front Driveshaft $40
- Rear Driveshaft $60
- Rear Passenger Door (100%) $150
- Front Passenger Door (100%) $150
- Front Driver Door window (main) $50
- Front Driver Door window (pocket) $40
- Rear Driver Door window (main) $50
- Driver door (front & rear) internals (let me know what you're looking for)
- Front Passenger Fender w/o Flare $100
-[I] Front Passenger Fender Flare SOLD[/I]
- Rear Passenger Qtr Panel Flare $40
- Sunroof Glass $100
- Spare Tire/wheel (Dunlap Rover AT H/T 31x70Rx15) $15
- Gas Tank Door and cap $20
- Front wiper arms and blade $20
- Rear wiper arm and blade $15
- Heater Unit (including heater core) $40
- Cooling Unit $40
- Rear heater unit $40
- ABS / TRS / VSC computer (89540-35270) SOLD
- Glove Box Airbag $100
- Stereo Amp Assembly (86280-35080) $35
- Running Light Relay Assembly $15
- Antenna Relay (85914-35010) $30
- 4WD Computer Control (89533-35170) $45
- Airbag Sensor Assembly (89170-35120) $75
- Hood Latch and cable $15
- Hood lactch assy (underhood) $15
- Gas Cap Door Latch and cable $15
- E-brake cable only - $15
- Steering Wheel pad with airbag $100
- Steering Combination Switch (lights) - $25
- Steering universal join $15
- Steering Column Hole Cover (2 different) $10
- Starter Switch Bezel $10
- Cluster Finish Panel $20
- Assist Grips SOLD
- AC Compressor $75
- Relay (90987-02012) - 6 qty $10/ea
- Running light relay (82642-35010) - 1 qty $25
- Rear wiper motor assy (85130-35070) $45
- Front wiper motor assy (85110-35280) $45
- ECU-5VZ,AT,4x4 (89666-35420) $100
- ECU-5VZ,MT,4x4 (89666-35131) $150
- Dash knockout cover trim - Qty 4 $10/ea
- Tailgate wiring harness $50
- Tow hooks Qty 2 $20 both
- Dimmer relay (85926-30020) $10
- Hazard light switch $15
- Relay (90987-02006) $5
- Turn Flasher Assy (81980-32010) $15
- Relay assy running light (82810-04011) $40
- Sensor assy Yaw rate (89180-35010) $60
- Brake pedal assembly $30
- Gas pedal assembly $30
- ADD actuator $40
- Rear spoiler light $15
- Fuel filler down tube $20
- Fuel tank with pump $150
- Complete Engine harness $125
- Engine Mounts - $30
- HP power steering line - $40
- Horns (86520-60160 / 85610-60190) $10/ea
- Auto tranny lower inspection plate $10
- Buzzer assy (89747-35010) $25
- Front diff skid plate $25
- Fuel tank skid plate $40
All PM's replied
Replied to all PM's. Thanks for your interest and I'll get back with more info as soon as I can.
Eric
Lift shocks for rear tailgate to 37167?
Hello,
I have a quote out to a local guy on the lift shocks and I expect to hear back within the next day or so. If that falls out, you're first on the list and I'll do $47 shipped.
Thanks and I'll confirm either way in a couple days.
Eric
I received the power lock actuator today. Thank you for super fast shipping! Will definitely buy again from you if I need something else.
do you have the front bumper valance in decent shape? I can pick it up, I'm in Wellington. :) Let me know and how much.
Awesome to see another local on here. Unfortunately I don't have the front bumper valance due to damage from the rollover.
Are you part of any local 4x4 clubs? I'm relatively new to Colorado and looking to meet some folks once I get my 93 up and running.
THanks for the interest and please let me know if I can help you with anything else.
ERic
Would you be willing to ship the passenger fender off to 96130?
I would be willing to ship the passenger fender. Just to confirm you are looking for the fender with the flare? I'll get back to you with a shipped price through PM soon.
Thanks for your interest,
Eric
Eric
Just the fender, no flare. Thank!
stc6306
