Parting out 2000 Toyota 4Runner West Chicagoland
I need the drivers or passenger front grab bar (located on the A pillar) They can be difficult to remove because of the factory loctite. I'll take whichever one is in better condition.
Well I️ got one out. I️ can drill out the other if you need two. 20 shipped for just the one. Thanks.
Just to confirm is this the one you want? [/IMG]
That's correct. Mine doesn't have a part number but it looks the same.
Edit: Actually I think the connector looks different. Not sure if there was a change between between 99 and 2000. Let me know how much you want for it, I really just need one of the gears inside so I may be able to cannibalize it.
20 shipped work?
Oil pressure sensor pig tail?
I need enough wire after the sensor as possible. I have solder the new pig tail on to my wire.
Can’t blame you. Sets are going in the 250+ range on eBay. Makes it tough to separate
Damn. Didn’t know they were going for so much. All mine are in good shape besides that one. Has a small blemish under one of the air vents. I’m thinking previous owner had a air freshener on the vent and the liquid leaked and damaged the plastic. Regardless, thank you for your time.
