Parts search assist.
2019 Nightshade. Dealership cant find this part, with vin. Confused.
So, if anyone knows of this part number, the little tray that goes into area where clock is, I would appreciate it.
Google “Toyota 0000049060” is that it?
Thanks a bunch.
And, one last question. To the right/left of the vents, there is the roller knob that you scroll to open or close vents. The little covers that go around them? Any chance you can get that number? Mine is an odd one, being a night shade too.
Thnx in advance
Actually the clock area isnt the correct part. Its the part in front of the clock that is missing.
I need to be seriously more thorough when I buy a vehicle.
Okay, its a T9. Its not stock, yep..
The dealership worked for a long time. That part is non existent, unless you buy entire stereo and bezel, vents etc. That is one unit..
Price was 6000 dollars. I shit you not. He was completely taken aback.
Salvage yards are my only option unless someone has one extra laying around.
Doubtful. Entire Bezel with plate..
there are a couple things you could do, if you can't find the OEM parts and understandably not want to pay $6K for some 25 cent plastic parts (unless you want an OEM head unit). you could get an aftermarket trim piece for the top like the lab ops mount. I think they make one that replaces the stock trim piece. it's like $80 IIRC. for the vent trim pieces you could get some aftermarket carbon fibre ones that stick over the or replace the stock ones and just use those, or even glue them on in the place of the OEM ones. you could even go match and get some carbon fibre trim pieces for the other parts of the console too
I will be looking. Problem is this is not OEM.
Eventually someone will have one out there
the parts you are missing are OEM. they are direct swaps from the OEM head unit to the aftermarket. if you don't like the aftermarket head unit try finding an OEM one at a scrapyard
Toyota Parts Catalogue
For future reference put your VIN and you can look at all the diagrams and part numbers for everything on your Toyota.
I believe your bezel is aftermarket since from what I've seen the aftermarket head units can't be installed in the OEM bezel. Could be mistaken. The vents and things have to be switched over to the bezel tho.
Try looking on Craig's List for a bezel. I've seen a few from time to time in my area. Actually saw a complete OEM bezel and head unit recently for $250.
I have been looking for a couple days now.
It is aftermarket. When they change to aftermarket, they take the vents and that little tray out, and swap it to the new one. The previous owner did not swap the tray over, for whatever reason. Lazy, missed it, or broke it. No idea.
But, the dealership and I went through all the drawings using my vin, and that part is not separate to purchase or have part number.
If anyone does a aftermarket swap, hopefully they can see a number on there.
So far, used trim panels are being sold with stereos, and range from 599 to 1000 dollars. But they all have that piece.
wow thanks. that is so much more detailed than using toyota part-buying sites which don't always have all PNs listed
That is a great site. Looks identical to the dealerships I was looking at when there.
In my case, when you drill down to the dash/stereo nav area, it says go to figure 86-03.. No link to it, just says look at it.
If that is the same as the dealership, it brought us to the 6000.00 dollar entire radio/nav center as a unit. Not able to break it down any further.
I am still trying every site, salvage yard ( went to 2 here) via websites of wrecked ones, craigslist, etc etc..
I have found several without that little tray. The rest are the entire thing with it missing, as this seems to be a trend when someone sells them after installing new updated aftermarket ones like I have. But, they remove that tray and the vents to the new one..
So, I have allot of feelers out there looking for it, or a part number if it has one.. Easy to see if you take out the stereo and peak under it.. Should have a number, as all interior parts should.
But, until then, if anyone sees the unicorn tray out there, please let me know.
Thnx
Jhunt
