Passenger Rear Turn signal quit working after light bar/ditch light install
ewokfarmer
Hello!
So I recently installed a light bar and some ditch lights on my 08 4runner. It seems like after I installed those lights, my passenger rear turn signal quit working. Bulb was fine as I tested it in the driver side socket without issue. Curious if I could have possibly cut a wire when going through the firewall with a flathead screwdriver? Fuses looked good, and I would think if it was a fuse issue more than one blinker would be out.
Anyone have any suggestions?
Test the sockets if you can. Mine had corrosion that was causing issues at one point. Sanded and greased the tabs and no issues since. Hopefully that's more where the problem is than a cut wire.
If it was a fuse it should be controlling more than just that light.
Otherwise you need to check where you penetrated the firewall and see if you cut something. Hopefully you can access the area.
Sent from my XT1650 using Tapatalk
seltzernator
