Phoenix area light install help
BikeDestroyer
Is there anyone in the Phoenix area that has experience installing aftermarket lights and would like to help me install these lights? Side Shooter LED Light Pod Pair I know it's probably a simple job but I have never attempted anything like this and would like to do it right the 1st time. The lights will be going on a 2000 T4R.
Purchase a dual light wiring harness with a relay. Very simple instructions will come with the harness. It is basically a plug and play set up. Use cable ties and a split wire loom where needed. You can do it.
Lay it all out on your work bench and see how it will all fit together. Install the lights, run the harness according to the instructions. The harness will come with a switch, so decide where that is going to go first.
Good luck.
Check out the Arizona 4Runners group on Facebook. When I moved to Arizona, I met a ton of great friends through that group. There should be somebody there willing to lend you a hand.
bobdjr41
