Pic Request: 265/70/17 or 255/75/17 w/o wheel spacers
jrm
Going with 2" OME/5100 mid-lift and cant make up my mind over tires. I wont be using wheel spacers and the running boards will be coming off. So if you have pics please post um up. Thanks
I went with 265/70R17s on my 08, and there was definitely some trimming needed without spacers (wider tire killed me). I added spacers, and it rubbed a lot more. I had to cut off some fender to keep it from consistently rubbing, and pushed the fender liner forward at least 1.5" -- at least... I'm on Bilsteins at top height and a leveling spacer in back to eliminate the rake.
My buddy has an 05 with 255 75s, and the flaps rubbed. That was the only trimming he needed to do without spacers. He added his spacers, and it was still minimal rubbing. He's got the same lift setup -- 5100s and spacers in the rear.
Net: The 05 & 08 fenders are different and may cause issues for you if you ever go the spacer route. If I had to do it over again, I'd go with 255/75s if you could find a good deal on them. The RBs shouldn't matter much either way. Also, the tire will make a HUGE difference. Knobby tires will rub more...but also look awesome.
Don't have pictures of my new setup 255s. But had 265s and I definitely regretted I didn't have 255s sooner
Here is a 265/70 pic
255/75/17 without lift
IMG_20150824_104517.jpg~original
255/75/17 after lift
170.jpg~original
255/75/17 after lift with 1.25" spidertrax spacers.
Cleghorn%20047.jpg~original
Honestly the 1.25" doesn't push it out very far and I think the stance actually looks better with them. Also fixed my rear remote reservoir rubbing issue. I did have to push the fender liners in the front forward, and I still need to trim something else because I still have some rub. Without the 1.25" spacer, I had a ton of rub on the fender liners and the occasional body mount rub.
Here you go. OME Low Lift and 255/75/17 no spacers.
Picture 1: Flower wheels. Lifted 2.5" with Bilsteins -- no spacers. These are 265/70R16s
Picture 2: 5th Gen Wheels. Same lift -- spidertrax. These are 265/70R17s
Picture 3: Profile of tires from the side. They match up pretty darn well. Very highly recommended.
Those are the wheels im going to use
what yr 5th gen are those off? And that's with 1.25" spacers? Cant wait to get it together.
255/75/17 No spacers
Those wheels are off of a 2012 sr5, and I have 1.25" spidertrax all around yes. I'm super happy with the setup -- get on it. :)
265/70/17, no spacers (FJ coils, 5100's, fronts @ 1.75, 1.5" daystar spacers in rear). Wheels look small in this pic, though they're not huge the rig looks better in person. Go figure.
IMG_20150617_181118_931_zps72oumwlp_1.jpg~original
Thanks everyone who contributed
Here's the result of your input. i think the rear 895e's will settle some reducing the rake. Really like the ride after removing Xreas.
Jhunt
