1 year post milkshake
Experienced the good ole pink milkshake 11 months ago. Since then I’ve put close to 15k miles on the dash. The 4Runner has been shifting nice and smooth since flush and rad change.
Immediately after noticing the spew coming out of my radiator cap, 4Runner went in limp mode so could not drive it. Had it towed to Amco where they replaced the radiator and performed a manual atf flush. After getting car back from them I drove it home and checked the atf fluid and it looked cloudy - hinting at there still being coolant in trans. The following day I performed a manual flush (draining pan and pumping fluid out of line going to radiator) all in all I probably ran around 30 qts of new atf fluid it. About once a month I check the atf fluid. Fortunately it’s staying pink with no stink. I believe I will not have any further problems with the trans unless the cooler in radiator fails again. For reference the it’s a 2001 SR5 4Runner - 285,000 miles.
Ok, so I had the dreaded pink milkshake. Searched this forum and found lots of advice on how to flush, and lots of opinions on either side on the effectiveness of a flush. I thought it would be helpful if we had a thread that captured some information on outcomes after experiencing the pink milkshake failure.
So, if you had the pink milkshake, please reply to this thread with your experience AFTER doing a flush.
Please include in your post:
Flush method used: (power flush, manual flush, pan drain only)
Approx how may quarts or gallons you used in the initial repair:
If you re-flushed after initial flush, at what mileage interval(s) did you re-flush:
If your trains is still working please state the approx miles accumulated since flushing:
If your trains failed, please state approx miles after flush:
I hope this thread will help accumulate some data on best practices and real data on flush effectiveness.
