Planning For Huge Lift 2WD-Open to Advice
liqourish
So Ive been researching forever to save up money and to come up with what i want to do to my rig which is stock with engine mods. I have yet to install my front spidey Spacers.
So far im thinking of getting these for the Lift
All Pro Fox Shox 2.5 Resi Coilovers/Rear Piggyback 2.0 Fox Resi (+3in front/+2in rear)
https://www.allprooffroad.com/fjfrontsuspension/fjcshocksfront/294(does anyone know how long the travel for these are?)
https://www.allprooffroad.com/034runnerrearsuspension/120
(will change out the brake lines for longer ones.
Complimenting those shocks with Total Chaos UCA ( found some for around 620$ )
https://www.sdtruckshop.com/detail.aspx?ID=117
And i will eventually go with Camburgs Spindels Which should be around 1g for another 4 inches of lift in the front. Also to balance the lift out abit i was wondering if using rear daystar 2in spacer will work.
Camburg Performance Spindle (6-lug, 2wd only)
so totaling 7in front lift and 4 in the rear excluding new tires
For the tires...im not so sure, but definatly Goodyear duratracs on stock urban runner 18in rims.
325/65/18 (34.6in)
295/65/18 (33.1in)
275/70/18 (33.2in)
Goodyear Wrangler DuraTrac
if the 34.6 willl work with that amount of lift id go that route. but could somebody explain the difference in 295/65/18 and 275/70/18.
May not go with spindles if it causes alot of problems, but thats a future upgrade i want to be able to do.
Comments,Concerns,and Good Advice is welcome!
This is a great forum for starters. But for something like this I'd post your question over at toyota120.com they are more technical and knowledgable concerning stuff like this
