Please advise
ashbata
Taking the front bumper off to install the tranny cooler, I simply cannot get the driver side turn signal to disconnect. Any ideas?
Seriously? Is it stuck in the housing???
There is a clip connected to the socket where you can take it off too.
Put the bulb back in and twist to lock, then unplug the wires at the light housing. There is a connection right at the end of the wires, no more than an inch long, it plugs into the back of the part you are trying to remove in the pic... Hope this helps.
Sorry guys I thought I deleted this post. I was messing with it, one side the bulb popped out of the socket and is rattling around in the housing. The other bulb shattered as I pulled it out. In wondering how the bulbs got in there if they were that big? Or do they expand with use?
they should be smaller than the slot it slides into..
The build may also come out of the front of those lights. I haven't done anything with those particular lights but it looks like there are two screws on the front of the light that holds the face on. Pull thee screws out and pop off the front cover.
Agree with PBR that the bumper doesn't need to come off. If you still want to though, you need to unscrew the front of the light, at e the bulb out (from the front), and then the bulb holder comes out the back. The bulb will not fit out the back.
YUP, BEEN THERE DONE THAT, havent we. mr muddy turn signals, haha remember that!
