PLEASE HELP!!! Brake/traction/&ABS lights on
Gus04Runner
So for about a month, i notice my brakes started to feel a bit soft with the first pedal push. Just recently it will go to almost the floor the first time i hit the brakes anywhere. I let off and re-apply and the pressure is normal. It did that for about a week straight. Then i hit my brakes one day and i heard the noise from the traction control.
Now my dash is a christmas tree with all the traction lights and ABS LIGHT. I have read on other forums this could be anything from an abs sensor, traction control module of some kind, or a faulty brake booster/master cylinder. I also read somewhere that it could be some kind of computer issue? Something like a $2,000 job.
If anyone has any input it or suggestions on what i should do first i would greatly appreciate it. I’m pretty capable of doing any work myself if need be. Thank you in advance.
First things first- get the error codes read. That can be done at any autozone or auto parts store for free (some mechanics may charge so it's just easier at autozone). That'll give you an idea of what you're dealing it. Then go from there.
dont drive it anymore. looks to me you need to replace the master cylinder.
Sent from my SM-G930T using Tapatalk
seltzernator
