I need help figuring out to do in this weird, difficult, and kind of unbelievable situation.
The gist of it is, there are some theorized issues with the camshaft journals in the engine on my 2006 SR5, V6 4Runner that have led a dealership mechanic to recommend replacing the engine. My 4runner has just under 90k miles on it and the suggestion is to pay $7300 to replace with a used engine with 130k miles
I've had regular oil changes and I don't think this damage is from neglect on my end. I'm going to outline the timeline below and hopefully give you all a better picture of what's going on. I'm so torn right now and I don't know what to do. I f*ing love this car and from what I see it's totally irreplaceable in terms of condition AND mileage.
Oct 2017 - bought the vehicle from consignment dealer, 62k miles. A few previous owners that didn't drive it much, last owner was older retiree who had it sit in garage but kept it in meticulous condition. No problems.
May 2019 - first real issue with Check engine light coming on, reading ABS sensor. Ebrake light also on. Had a local smaller mechanic shop remove and look at sensors, they cleaned them and put them back on, which made the lights go off, but they eventually came back on. They said it might be a computer problem and may be very expensive to diagnose and fix so I started mentally and financially preparing for that. Lights would cycle on and off over every few days, the speedometer would not work if the ground was very wet so, at this point, I'm thinking it's the wiring but overall seemed to run fine.
December 2019 - drive home for the holidays (900 miles away) and let my dad do some general maintenance. He replaced spark plugs and saw oil on one of the plugs in the cylinders and freaked out and immediately figured it was super bad. I took it to the trusted mechanic in my hometown and they guessed it was a value seal, which they replaced, and that seemed to fix that problem. I, unfortunately, I didn't have the time to wait for them to try to diagnose the wiring issue since they were booked for a week.
April 1 2020 - drove home to AZ due to COVID-19 and figured this is a great chance to get this figured out (stimulus money / more free time / labor is cheaper in my hometown versus Denver). Half-way thru the trip, as I was pulling out of a rest stop, my car shuddered and flickered the oil light at only 10 mph when I pressed gas, so I quickly pulled over. Checked oil, which seemed low, so I added a half quart I had with me. Drove back and forth on side of the road slowly, couldn't reproduce it so I got back on the road and didn't take it above 2k rpm the whole way back, no issues. When I got back, took it to my ex since he knows the vehicle well and we did an engine flush with SeaFoam in case there was buildup affecting how the engine ran. Changed oil after that and oil was definitely cloudy. The engine did sound smoother during driving and idling.
Took it to my trusted mechanic in AZ, they figured out it was squirrel damage so replaced the abs wiring harness, and the crankshaft sensor was not sensing so replaced that too. They test drove and gave it the go-ahead. I drove around for another 150 miles to see if the lights would come back on, and changed the oil right before leaving and the oil looked clean. Lights were off for 4 days after about 150 miles of random driving so I decided I'd be fine and started the 900 miles back home. 100 miles into the trip, CEL comes back on. I stop at an AutoZone to read the code - crankshaft sensor again. Ok, I'm not turning around at this point I'll just take it to the Toyota Dealership because I live close when I get back home. Included below is the report from the dealership. Spoke directly to the mechanic and he said there were tons of metal shavings on both camshaft sensor and crankshaft sensor. They used a scope and located the rattling sound to the camshaft journals and values, and he said he doesn't think the valves are making that sound.
*****Dealership Write-up******
C/S THE CRANKSHAFT SENSOR WAS JUST REPLACED OUT OF STATE. CHECK ENGINE LIGHT IS ON
TECH FOUND CODES P0335 AND P0340 FOR CRANKSHAFT POSITION SENSOR AND CAMSHAFT POSITION SENSOR. THIS ENGINES ARE KNOWN FOR CAM GEARS RECTOR WHEELS BRAKING OFF AND CAUSING CODES TO TRIP DUE TO SENSORS NOT BEEN ABLE TO READ CAMS POSITION.
* NEED TO START BY REMOVING VALVE COVERS AND INSPECT ALL FOUR CAMS FOR ANY DAMAGE. MAY NEED OTHER REPAIRS
Additional Service Repair
REMOVED BOTH VALVE COVERS TO INSPECTED VEHICLE FOR CAMSHAFT/CRANKSHAFT CORRELATION CODES. INSPECTED TIMING AND IT WAS WITHIN SPEC. INSPECTED CAMSHAFT GEARS AND THEY ARE IN GOOD SHAPE. FOUND A LOT OF METAL AROUND THE TIMING CHAIN AREA. TIMING CHAIN HAS A LOT OF WEAR. WENT AHEAD AND REINSTALLED VALVE COVERS AND TEST DROVE VEHICLE. NOTICED THAT WHEN UNDER A HEAVY LOAD OR REVVING ENGINE IN PARK, THERE IS A LOUD RATTLE FROM THE VALVE TRAIN. SUSPECT THIS IS WHY THERE WAS A LOT OF METAL IN THE TIMING CHAIN AREA. WILL NEED TO REPLACE THE ENGINE ASSEMBLY (CAN DO CYLINDER HEADS AND RELATED PARTS BUT WILL BE WAY MORE EXPENSIVE THEN JUST DOING A USED ENGINE).
* REPLACE ENGINE ASSEMBLY
I'm sorry this is so long, but I desperately need help. I have $3400 left to pay off on this before I own it outright. I don't have 7k to drop but I can take out equity on the loan to cover the repairs, but I'm a baby adult and don't know if financially this is a good call.
I have thought about rebuilding but the dealership mechanic's argument was with metal shavings everywhere something else could be damaged and cause problems down the road. I don't really understand all the details but for rebuilding wouldn't each individual piece be inspected for damage? A replacement engine also comes with unknowns. I also found basically my exact 4Runner for sale in my state with 17k more miles but looks to be in great condition. Not sure if I should consider selling mine and just cutting my losses, or pour money into it and keep it forever.
I am going to try and attach some links of videos of the rattling sound they mention when I rev the engine in idle so there's some kind of reference. Otherwise, everything runs smoothly unless I really lay into it. I was told it's safe to drive it's just obviously not good.
I feel like my only options are rebuild, replace, or just sell and try to find something similar?
THANK YOU for reading and any advice would be super appreciated. If anyone has suggestions for good Toyota mechanics in Denver, please let me know, I don't have much of a support community up here for help!
Idle - 20064runner-idle.mov - Google Drive
Rev to 5000 rpm - 20064runner-revto5k.mov - Google Drive
