1985taylor1925
Senior Member
If you're looking at it from the front, facing the truck:
(windshield)
5-6
3-4
1-2
(Front Grille)
^^This is the cylinder number order. This is not to be confused with the wiring or the firing order which are different. The coils sit on top of Cyls #1, 3, and 5. Each coil has a boot (like I mentioned before) that goes directly to the plug underneath it and also a wire going to another cylinder on the driver's side. So each coil pack fires 2 plugs. The wiring/coil order is:
-The coil on top of #1 also (has a wire going to and) fires #4
-The coil on top of #3 also fires #6
-The coil on top of #5 also fires #2
Make sure your plug wires are routed this way, if not the engine will run like crap and not fire in the correct order.
Got it. Thanks a ton. Im gonna work on it tomorrow morning
