Lugnutz
New owner here! 1998 4X4 SR5 with 131K. I have no prior history because I bought it at an auction - cheap! :wink2:
Horn doesn't work and interior courtesy lights don't come on.
I think I found the problem, just wanna run this by some folks since I don't diagnose wiring problems as good as I should.
When I flipped the fuse box over and I saw that the Blue/White wire connects to the passenger side of the fuse linkage, BUT THERE IS NO WIRE ON THE DRIVER'S SIDE! I cannot find any loose, bare, broken wires that may have pulled loose, so I am wondering what to do.
I need suggestions on what to do next. I need the horn to work and interior courtesy lights sure would be nice at night.
Haynes manual was of no help at all.
The same is true for the Blue/Yellow wire for the interior courtesy lights. One wire at the fuse.
See photos.
Before posting, I did test a lot of stuff.
Horns test OK.
Wiring at the steering wheel looks factory with no modification.
Fuses are fine.
I traced the wiring harness from the horns and the main harness to the fuse box under the hood. Also looks untouched.
See photos.
Horns test OK.
Fuses are fine.
