plz help. annoying noise
cooljello6233
when ever my 4runner is is motion i hear this high pitched squeaking sound that stays at a constant drone and the faster i go the louder it gets. do i need to lube something to make it stop? (its comin from the wheels i think)
quick thought maybe something stuck in brake rotor area between rotor and backing plate or a wear tab rubbing indicating you need new brake pads.does it come and go or go away when applying brakes? just a though!
If indeed it is the brakes, and you are interested in replacing them yourself, I can instruct you on a great brake job. Don't just slap some pads on. or let someone else do the same. You will end up with some issues for sure.
ian2328
