Poor acceleration fix?
Bml_merris
I've read on different forums and noticed myself that the 3.4L V6's in our 3rd gen 4runners have poor acceleration and are feel sluggish. Has anyone found a way to fix this issue, or make it any better? Would prefer to have decent acceleration without using ECT all the time.
Sent from my SM-G930V using Tapatalk
Supercharger or buy a 4R with a V8 or even the 4.0 The 3.4 is under powered, not much you can do about it.
I just can't justify dropping two and half thousand on a supercharger. That's over half of what I got the vehicle for to begin with, lol.
You'll be into it for a lot more than $2500 said and done lol. Sell it, buy a V8 runner or one with the 4.0 Both are significant upgrades over the 3.4 You can do little things like synthetic oil, more free flowing exhaust and intake, quality spark plugs and wires, synthetic diff and transfer case oils. It all helps but none of it will be significant.
The 4.0 isn't a huge bump in power when you factor in weight. The curb weight of 3rd gens (4x4) is roughly ~3950 lbs, where 4th gens are ~4300 lbs and 5th gens weigh up to ~4800 lbs. That's a weight increase of 9% and 21.5%. I test drove a 2018 4Runner and was very underwhelmed as far as the engine goes. Even my wife said it was a slug trying to get on the freeway and she doesn't drive my 4Runner half as hard as I do.
The 4th Gens with the V8 do have a noticeable amount of power though. Lots of low-end torque where you will notice it.
For the OP, here's a few things you can try:
  • Do the "deckplate" or "elbow removal" mod. Gains are around 5 HP on an N/A engine
  • If you have a 96-99, remove the slack in the throttle cable.
  • Make sure your spark plugs & wires are in good shape
  • Switch to sythetic fluids in the transmission and engine
  • Install a lightweight flywheel (doesn't add HP but reduces rotational mass)
  • If you are a glutton for punishment, headers increase HP but more so with a Supercharger on it
You can find a used supercharger in the $1000 range even today. If it's a black 2nd gen, you can rebuilt it for as little as $150 and nothing else is needed. That will give you the most bang for your buck. Fuel mods are not necessary for the supercharger, only if you want to make more HP.
I agree on the 4.0 until you put some miles on it. No idea why but once you hit 10K they open up a little, 20K they open up a little more. I'm lifted on a 295, 90 pounds each wheel and tire, stock gears. I have zero complaints other than of course I wish there was a V8 option.
