Poor Gas Mileage in Cold
quatin
I've noticed my 4 runner has poor gas mileage when it gets below 60 degrees outside. Coincidentally, it's also the temperature when I start to hear "piston slap". Normally I get 20mpg+ in my routines, but a couple of weeks in 60 degree weather it'll drop to 18mpg. Anyone else have this problem? Am I correct in assuming the two are related?
I speak for everyone. Your lucky to get 18. And yes it is normal to get lesser mpg's in the winter
Just to clarify. I live in Florida, so we don't get winter in a season form, but just waves of cold fronts. Using the same tank of gas (1 tank lasts me 3 weeks), I will notice my MPGs drop for the week we have the cold front and shoot back up when the cold front passes.
MPG's definitely drop with cooler weather. Here are a few reasons based on an article at about.com
Cold Weather Vehicle Fuel Mileage – Why Winter Fuel Economy Drops – Fuel Mileage Drop in Vehicles
  • Cooler temperatures means more viscid fluids, ie slightly more friction.
  • Cooler temperatures mean low tire pressure, and as it is generally known that improperly inflated tires get lower MPG.
  • Air-fuel mixture rates are set for optimal running temp. When the engine is cool, say around 60 degrees, it is not going to have an optimal fuel-air ratio.
Just a couple ideas to give you some kind of an answer. Hope it helps.
Ok, cool. As long as other people have noticed this too. I was wondering if my O2 sensor or my MAF sensor has gone bad.
Yah I'm feeling super happy if I get 15MPG in the city in winter. I've even had a couple 11 MPG tanks! Canada sucks sometimes.... :canada:
DJNutshell
