positive camber!!
boostedprozac
I've had my older daystar 2.5/1.5 inch lift for about 20k now. I got an alignment right after I installed the lift but now I'm starting to see lots of wear on my outer tread of my front tires. Is there anything I can do to help lessen the camber effect? Should I get another alignment adjustment? I understand the nature of lifting the car... just wanted to see if there was much I can do.
Yes, do another alignment. Have them put the back tires on the front just prior to the alignment so as not to align to uneven tires.
Camber should be fine. When you lift a T4R with stock UCA's the caster is tough to get ideal but the camber should be fine. With the Daystar 2.5 even the caster should be ok. You really have to go higher than that (it seems) to have the caster become an issue.
:cheers:
tuṣṭāva
