Possible 2015 4Runner 4X4 purchase.
All good advise above, I’ll add my 2 cents
*ATRAC vs. Locker, not as good but my general opinion of debates like this is if you have to ask if you need a locker you are likely not going places that require one (I realize that is not what you were asking but treat it as a want vs. a need) - I fall into the category of buying it and not needing it, but it has helped a few times without a doubt
[MENTION=104049]marshal[/MENTION] is there Toyota literature on the systems being programmed differently between the SR5/ Trails, that’s news to me
*Transmission cooler, 15miles round trip I wouldn’t even bother, if you are really concerned drive slow and if the transmission temperatures do get elevated I ASSUME that you would through a code/check engine light which would be a good indication to slow down. If you want one for comfort It wouldn’t hurt but I don’t think I have ever seen an OEM cooler installed here. If it is integrated into the radiator it may not be possible or at least $$$ vs. just an aftermarket option
*Alternator, as you mentioned it’s not needed. There is a thread someone where on here IIRC that had an upgraded alternator but I think there were some issues with the install, no idea if it was resolved or not but worth a quick search if you ever decide to go down that path.
*Shocks , sound like a perfect candidate for Bilstein 5100’s from your choice of vendor
*Electronic vs Lever actuated Transfer Case: While I fall into the camp that loves my lever and was one of the main reason I bought the trail I would not say its worth it over the cost of the SR5 if you don’t value the other things that come with it such as trail wheels, hood scope , black interior trim, front and rear silver valence trim. crawl control, KDSS option, etc………to everyone those options etc are worth more or less, I liked the looks of the interior and exterior much better on the trail and had no plans to upgrade wheels so for the cost difference the Trail was the best value IMHO.
Valid points. Thank you.
[MENTION=96008]Engineer[/MENTION]
im not sure, I've heard it from multiple reliable sources that the Trail received the ATRAC that the FJ Trail Teams was programmed with, which was much more aggressive than the standard ATRAC.
Cool.
Maybe [MENTION=66389]BlackWorksInc[/MENTION] can help us out,
....OP, sorry for the thread high jack.
No worries at all man.
As far as the leather, only the trail Premium has the faux leather which is waterproof and easier to clean than the fabric.
Just go on Toyota's web site and compare the difference between SR5 - SR5 Premium - Trail and Trail Premium.
I was looking at a Trail Premium, couldn't find one and ended up getting a great deal on a TRD Pro last week.
Cool. Will do.
OP
Another thing worth considering is either stiffer rear coils or air bags since the boat is close to the towing "limit" you rear end WILL sag..
[MENTION=131012]Bradysdad[/MENTION] It's not the trim level, but the attitude some people have.. I also agree that is a cool avatar
True. Matter of fact I was looking at ToyTecs offerings. I may go with OME rear springs that hold about 400lbs more weight than stock. I'll definitely talk to ToyTec and see what coil springs they recommend for me.
Hello group,
I called a Toyota dealership today (one who's parts & service dept I've dealt with for years) and asked if they could install an OEM Tacoma trans fluid cooler once I buy the 4Runner. The service rep put me on hold and returned after almost 3 miutes and said that it wouldn't work.
He did tell me that if I take them an aftermarket one, they would install it and top off the transmission accordingly. I get a discount with them on labor due to my job at Good Year. I think it's a good move and they won't give me BS on my trans warranty since they did it. Of course, if the trans cooler itself fails then that's different but it's pretty rare for that to happen.
I also called 3 transmission shops and they all rexommended the Tru Cool line. I didn't ask if steel or aluminum or what size. They also said it it shoukd be LPD, stacked?, I think.
Well, looks like I'll be going that route for now. Anyone running Tru Cool stacked coolers?
delislerebecca
