so these 2 codes kept popping up after 1 or 2 days after clearing them, C0200
C1223, so i knew something was wrong...i took off the right front tire and tried backing off the sensor, no dice..the bolt looked like an allen key or something, then i remebered that 2yrs ago when the mechanic worked on my control arm, he didnt route the abs cable properly and it ended up rubbing upon the tire, and shorting out 1 of the inner cables in the harness and resulted to my having the dash lit with abs/vsc lights .
so i peeled the covering and spliced and joined the cables, the lights on my dash disappaered, fast forward today, i checked the splice, twas still holding up strong, i decided to peel out the insulating tape and discovered that the white inner cable had pulled out and wasnt joined anymore. i joined another cable to it and tapped everything up...will observe for a few days and report back.
read up somewhere that the abs harness doesnt like being spliced andjoined...due to differences in resistivity/conductivity........so i intend buying another abs sensor+harness whenever the lights come on again
qucik question; the bolt holding the abs sensor..is it an allen bolt/..what size?..any special tricks in loosening it?
