Potential 4th gen purchase issue
hearno
Senior Member
I'm getting ready to look at this truck tomorrow. I noticed the rims looked weird and realized they're 3rd gen rims on a 4th gen truck. Does anyone know off the top of their heads whether or not those rims are correct offset etc to be mounted on a 2004? Thanks.
I know my stock sr5 wheels were a 30 (mm) offset, I believe the ones on this truck are a 20 (mm) offset.So therefore , these (3rd gen wheels) do stick out slightly further than stock wheels on an 04. You should be fine, they might stick out 3/8 of an inch more max, i have no issues running my 15 (mm) offset wheels. Other 4th gen factory wheels were 15 (mm) offset from toyota, and they work just fine.
EDIT: Someone please correct me if I'm wrong.
I wouldn't let those wheels be a deal breaker. Heck, you're going to end up replacing them sooner or later anyway!
You're correct. I was just concerned about damage to the hub/studs from driving on wheels not designed/compatible for the truck.
I'd be more concerned about brake clearance. But, if there was an issue you'd know it by now. Those are 16" wheels, right?
All previous generation 4runner wheels are compatible with each other , the only incompatibility issues you'd run in to would be with brake clearance.
Which shouldn't be an issue unless its a sport. And maybe some limiteds.
tuṣṭāva
