Potential Setup
Iron Clad Lou
I'm currently running 265/70/17 BFG's, I'm planning on a 2/1 Cornfed lift and adding Spidertrax 1.25 spacers...does anyone have this set up currently?
I'm not too worried about the spacers as my T4R is not a DD....I am concerned more about any rubbing....I found a different off road shop I'm going to visit on saturday...and now that I have the cornfed instructions and a place to disconnect xreas, these guys should be able to do the lift!
Lou, I have the Spidertrax spacers & the Cornfed lift on mine. I'll check the directions that came with the spacers and get back to you...
thanks guys...holzapfel, you have a 3/2, right?
I dont have tire rub now, and I shouldnt with the 2/1 and spacers, right? at least I think I shouldnt...
the spacers need the loctite. Wether u use the provided loctite or if you have the kind in the blue bottle it is the exact same. They should be torqued to 85-100 ft.lbs if I remember correctly then torque your lugs to the factory 76 lbs. super easy to do.
just take them off the same way you put them on. Use a torque wrench so you have some leverage, the nuts will come off. Just make sure to reapply loctite if you take them off.
you should be fine. I still have the stock 265/70/17 tires on mine and it barely touches the front mud flap when at full lock in reverse. At first I didn't notice it but I was backing out of a parking space with the window down and heard this barely noticeable noise. I couldn't hear it with the radio on or feel it in the steering wheel. Give it a try if it rubs take off the front mudflaps as you will have to if you want the 285/70/17's on there after you put on your lift.
I would stay with the 265/70's ( personally)
Rod n Gun , the stock tires are 265/65 correct ?? I had to upsize to 265/70's sine mine came w/65 series as do all of the models now.
I don't know, I thought the limited's with 17's had the 70's, I bought mine used and that's what came on it so I am not sure what it originally had on it.
