Power steering pump
89yota4x4
Fluid everywhere looks like a power steering pump..... Coming from the part where the pulley connects to pump... Gasket job easy fix or junkyard replacement ($50)? What's the best way to fix n most reliable thanks
Unless you are positive where the leak is coming from, and unless you can get rebuild parts from the dealer, just get a remanned one from the local parts store and be done with it.
Of course a little more info like is it from the 4 cyl or V6 might help a bit too.
I had the exact same problem. '89 with 3.0 and leaky power steering pump. I rebuilt it with a gasket kit of ebay. Wasn't too bad, just be patient. Taking apart the pump was interesting and a little time consuming. Probably took me a good 4 hrs. My time is cheap though. Probably leaking through the front oil seal right behind the pulley. All the gaskets were dried and brittle on mine. They just broke apart. If time is an issue, I'd just buy a reman.
