Powered sub under passenger seat
marlinsfan
I tried searching but could not find anything.
Does anyone have a powered sub under the passenger seat? Wondering what options there might be that fit the 5th Gen
I currently have a mono amp under there, and a small 8" JL Audio micro sub amp in the trunk, powered by a old JL Audio e1200 mono amp (120W) under the passenger seat, but more and more I'm putting up the third row and having to take out the sub box due to the small trunk that's left when the third row is up.
These are ones I see that might work, but have no idea on the fit:
Sound Ordnance B-8PTD 125-watt compact powered subwoofer at Crutchfield
Sound Ordnance B-10AS Single 10" sealed subwoofer enclosure with 100-watt amp at Crutchfield
RetroSound SUB-8100 Compact powered subwoofer: 100 watts and an 8" sub at Crutchfield
JVC CW-DRA8 Compact powered subwoofer: 150 watts and an 8" sub at Crutchfield
JBL BassPro SL 8" compact powered under-seat subwoofer enclosure at Crutchfield
https://www.crutchfield.com/p_108BASSLSM/Infinity-BassLink-SM.html?tp=114
https://www.crutchfield.com/p_113KSCSW11/Kenwood-KSC-SW11.html?tp=114
https://www.crutchfield.com/p_130TSWX130/Pioneer-TS-WX130DA.html?tp=114
I would go with the Alpine, I had it all picked out before I went with my JL in the stock speaker box. If I couldn't fit the stock sub box I definitely would have done the Alpine
I have a Kenwood powered sub under my drivers seat and then added Focal ISS690 speakers in the front doors/dash. That was a huge improvement from stock.
Last month I installed the Kicker Key 180.4 amp under the drivers seat with the sub. That proved to be the difference maker. If you are going to add the sub I highly recommend adding the amp for the speakers too if you haven't done so already - made a huge difference for the speakers and the overall sound quality.
It's a bit tight under the seat but it can fit.
Take a look at this thread regarding installing the powered sub - it proved very useful for me.
Speaker replacement & Sub addition
Im running these under my seats.
https://smile.amazon.com/gp/product/B00OYGGMXK/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
No issues at all with clearance and no mods needed except removing the foot vent deal
Sound is pretty good considering the line input and the small space.
It is in no way a replacement for a full amp/sub combo.
This is very helpful, thanks. From your alpine I can see the dimensions, so now I know what fits.
My 'full' amp/sub combo is not a very powerful one. I mis-typed above, I currently have an 8" micro-sub from JL audio powered by a 120W mono JL Audio e1200 amp. While it's amp/sub combo, it's not anything to write home about.
Alpine makes a Runenr specific kit:
Alpine | PSU-300FRN
So you have the Kenwood powered sub AND the Kicker Key amp under the same seat? What model sub is that?
I already have a 4 channel rockford fosgate amp under the driver seat powering all the speakers, which are not stock speakers.
Glad to help.
I see, yes in comparison to the micro sub I think you will be happy with these, I wired into the rear channels so that along with the EQ I can tune the sound more front for less bass.
On that Alpine model, there is also a bass knob option that I am not using as well as HP/LP filter knobs.
I have a Pioneer powered sub under the passenger seat. It seems to provide all the bass I really wanted, and doesn't restrict the air vent in any way. As an FYI, there is a detailed installation procedure in the Modification sticky above, entitled Subwoofer Install.
Which pioneer do you have?
Both the powered sub and amp are under the drivers seat. The amp is a micro sized amp - very small footprint with DSP. I was able to leave the vent under the seat as well. The sub was screwed into place and I used velcro on the Kicker Amp (like [MENTION=147186]Heavy_GD[/MENTION] pro tip). The powered sub is a Kenwood KSC-SW11 - they may have a newer model now.
If you are looking for something to 'fill in' then an under the seat powered sub will do just that. If your intentions are a BIG BOOMING sub then look at a different solution.
I'm not looking for booming. I'm looking to replace a 125 w amp and 8" micro-sub with something similar that takes up no space, as the trunk space has increasingly become more premium as the kids are getting older and the third row is getting more use now than 4 years ago when I bought the T4R and replaced the entire sound system.
If you have the third row, check out my solution here. Just would need to source a JBL stock speaker enclosure
Third row seat removal to access rear panel pocket, subwoofer install
More involved than a powered sub, but so worth it
I had a Kicker hideaway sub, HATED IT. It really did the absolute minimum to provide depth to my music. I ended up disconnecting it and went and bought the stock JBL sub box (comes installed in higher trim 4Runners w/JBL sound system) and had that modified to support a JL 8" box. It's now tucked hidden behind the rear panel and gives me all the bass I need without sacrificing a single inch of space in my 4Runner. LOVE IT.
2001ATL
