Premium gas on GX 460
This is up to you to decide what you are comfortable with.
I have run regular in my GX for years now with no problems.
My wife's MDX, on the other hand, will very noticeably knock if you put anything less than 93 octane.
Over at clublexus, there are several threads which discuss this ad-nauseam. The fact remains that this is the same exact 1UR-FE that's in the Tundra, which recommends regular, and is actually rated to make more horsepower than the Lexus GX. The comparison is even clearer when it comes to the Landcruiser vs LX570 which again use the exact same engine, same part numbers, etc.
You'll find that the consensus on the LX570 forums seems to be that regular is fine, with just a handful insisting you need premium, whereas consensus on the GX460 forums is that you need premium, with fewer who think regular is fine. Seems like the wealthier LX guys like to save a few bucks and put regular in the tank, whereas us upper-middle-class GX drivers think we need to protect our investments with premium gas. Go figure.
Again, do your own research, make up your own mind. Personally, I like saving the ~$15.00 per tank.
So I’ve been running regular pretty much since we spoke last. Mostly filling up at Costco. Runs fine but there is a little difference in power. Not a huge issue as I’m 80% of the time just driving the kids around the town to school or such. I don’t see a difference in MPG bc I’m idling a lot.
What’s your take of resetting the ecu? I’ve owned the vehicle for maybe 4-5 months. I did not do this on the Lexus when I first bought it but I’m pretty sure it’s learned my driving habits by now.
I have never reset the ECU, however I have disconnected battery/swapped battery though I do not believe that resets the ECU. You'll lose your settings but if you've only been in it 5mos that might not be a big inconvenience.
Lots of traffic really kills the MPG in these things :laugh: but running regular can take the sting out of fillups.
Personally I have seen zero difference in premium vs regular. However like you I'm not giving it the beans very often.
25k on my 2017 GX460 and always ran 87 octane cheapest gas. I average 18mpg, zero issues.
It's not that it won't work, it just retards the timing a little to compensate...
You loose a little performance to accommodate the fuel. Not ideal, but it will work.
RennSport2UZ
