Preventitive maitnence
983RDGEN
Ok guys I'm putting a new motor in my 4runner. 1998 V6 4x4 I'm planing on doing the t-belt water pump, cam, crank, rear main seal, reseal the oilpan, valve cover gaskets, new clutch kit and flywheel, can anyone think of anything else I should do to the motor or the truck before installing the new one?
There are two o-rings for the oil cooler. Less than $10 for both. OEM parts only.
Also take a look at the brass plugs and if the starter contacts have never been replaced, replace them too.
Good luck.
REE
