Dear Ambush,
Thanks for replying to my post. No check engine lights or anything like that are on. And no, it doesn't act like it doesn't want to go, it just starts vibrating when the gas pedal is pushed. If I pop it into neutral and press the gas, it doesn't shake or anything, only when it is in drive. Last month, I replaced the O2 sensor, got an oil change, and a smog check. So aside from the O2 sensor, I haven't had any other issues. Does that sound like anything you might have heard of?
Originally posted by ambush
Yup happened to me b4.
MAF signs going bad. It acts like it does not want to go when you hit the gas too huh?
BAD gas, dirty air filter or ECU just needs to be reset (remove neg terminal from batt for about 30 mins)
